Mark, I see lots of work and love getting this kind of results takes both. You have done very well, as Mr Grace would say on "Are You Being Served" and this TR6 should serve you well. Hope you get the overdrive to work, I'm sorry you bolted it all back up before checking it out, hope it's just a relay or crossed wires. Does your ground wire off the battery have the clip on it that bolts to the firewall, if so, clean a bit of paint off the hole and bolt it on, makes a difference. Once again, great job. Wayne
