New Tools in my shop, need some lessons
Jerry
Group,
Anyone live in the Sacramento area (Northern CA) that knows how to run a milling machine and large lathe? I have a Steinal mill, and LeBlond 13 inch lathe installed. Older units but would like some pointers in how to use them. No, I don't have a manual to either yet. I am still searching on line for that.
Jerry
Billm
Jerry
I have a friend who lives in Sacto and teaches machine shop at SF City college.
Want his info? I'm sure that he would love to help!
BillM
TR3driver
Great Pumpkin - R.I.P
I'm too far away to help directly, but I'll throw in a plug for "Home Shop Machinist". Although they also cover the micro machines, there are a lot of good "how to" articles for medium size machines.
https://www.homeshopmachinist.net/home?noredirect=true&noredirect=true
The sister magazine "Projects in Metal" also has a lot of information on how the authors solved a particular problem, again frequently using medium size machines.
Lindsey Books is another treasure trove of information:
https://www.lindsaybks.com/
The old South Bend books have a lot of information that applies to almost any manual lathe.
https://www.lindsaybks.com/bks/lathebk/index.html
For my Atlas lathe, even the Atlas manual didn't give spindle speeds; and I've never found a manual for my vertical mill (which is actually a converted horizontal mill). Took me a long time to even figure out that there is a gear train inside the pulley cone! So this tool comes in handy:
https://www.harborfreight.com/digital-contact-tachometer-66400.html
Banjo
Step one: pack them up on a cross-country truck, and address them to me! hehehehe.
I'm too far away to be of any assistance, and don't know squat anyway. I'm heading down that same "expanding my skill-set" road as well. You got a big step on me, as I don't have a mill or a lathe yet.
Best of luck.
J
Jerry
I have a little lathe, a 3 inch jaw model. I have been able to do the basics with it, but the large 13 inch model could be more fun if I learn how to use it. I read a basic book so far , but it was far to basic.
I have not done anything on the milling machine yet. It could have projects on the car restoration and repair.
So far my wife says retirement is good, I spend all my time in the garage.
Jerry
Banjo
Well, If you're retired, and have a flexible schedule, why not look into a course at a local community college or vocational school?
J
Jerry
Ran the milling machine yesterday to cut down some metal for a car. I figured out the controls for what I needed to do yesterday. I also bought a "manual" off the internet. They downloaded it to my computer. It was crap for $150. 20 pages of what I would call a sales brochure. It says what you can do somewhat with the machine, but not how to do it.
I sent them a note on my displeasure and they offered to look for a more specific manual.
Jerry
Hey Jerry,
do you know the difference between climb milling and conventional milling?
m
Billm
Jerry
Did you get together with Mike?
He told me that he would try to contact you.
BillM
J
Jerry
We exchanged a bunch of email. I invited him over to see what I have to work with, but have not heard back from him since last week. He did invite me to attend the class he teachs, but I have not decide on a free date yet.
Jerry
Billm
Mike gets pretty involved in lots of stuff so the fact that he hasn't gotten to you yet is not a big surprise to me. He is a great guy (and a HUGE Mini freak) and will help you with your stuff.
Bill
JPSmit
DNK said:
Billm said:
...HUGE Mini freak)
Uh...Isn't that redundant Bill?
Not quite:
Mini + freak = redundant
Huge + Mini Freak = Oxymoron.
:devilgrin:
Platinum
HERE is a HUGE Mini freak. Or a Freak HUGE Mini... or a HUGE freak Mini.
Billm
Well- you are all close (but no cigars)
Mike's nickname is "Animal" and he ain't a small guy. His first car was a Mini Cooper S that his mom had raced before he was born, but he turned out OK anyway.
BillM
J
Jerry
I noticed Mike was into Lemons racing, so we have a lot in common. We are running a Cortina in the March Infinion Lemons race. I spent some time on the Lathe this weekend, and was able to get the milling machine going also. I figure out to do some simple things.
I am hoping to get the Cortina running by the race time!
Jerry
I've got Asian Bridgeport mill, and a Clausing variable speed lathe 14x60 lathe, I took a tool and die machine shop class at the local tech college years ago, it was worth every penny. I would not call myself a tool and die machinist, but I use my machines to do the various jobs I need to do to my modded MG motors. Some of the stuff they taught you at T&D class seem redundent at the time, but has turned out to be very valauable, like being able to custom shape and sharpen a cutting bit to do something different than store bought cutting bits. Also a big lathe makes a great place to mount a crankshaft, I use it to hold the crank and make measurments, and then also run on real low speed and polish cranks as well.
J
Jerry
I will need to trim a TR3A crankshaft for a rear seal. Can I do this on the lathe or will it be too unbalanced?
Jerry
TR3driver
Should be do-able if your lathe is big enough. But I think you'll want a tool-post grinder rather than trying to single-point it; and centers big enough to engage the holes in the ends of the crank. Need a pretty big wheel on the grinder, too, to reach in between the #4 throw and the flywheel flange. Keep the lathe turning slowly enough, and balance won't be a problem.
Personally, I'd take it to a crank grinder anyway, just because I'd hate to screw it up.
But I'm curious, why are you messing with that troublesome old seal conversion, when the new "Mad Marx" version works better and doesn't require machining the scroll off? Seems like a no-brainer to me, especially given all the horror stories of seal conversions that leaked much worse than the original seal (which actually does pretty good if you set the clearances right instead of following the book).
JPSmit shop tools Restoration & Tools 3
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
Popeye Bojo trim tools Restoration & Tools 7
DrEntropy Came across these "tools" Lotus 2
M TR6 Tools? Triumph 14
B Road Tools Restoration & Tools 6
7 paintless dent removal tools? Restoration & Tools 8
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
7 No more Bosch tools for me Restoration & Tools 4
Michael Oritt Special tools for LBC'S Austin Healey 25
M TP Tools vs. Harbor Freight Restoration & Tools 12
JPSmit Interesting tools as gifts Restoration & Tools 1
BN6_2197 Question on tools and spare parts for lonng distance drive Austin Healey 28
bugedd Tools to travel with Spridgets 11
PC wanna buy Craftsman tools? Restoration & Tools 5
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
G General Tech What tools are these? Triumph 9
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
LarryK Whitworth tools Restoration & Tools 5
JPSmit New Tools - woo hoo! Restoration & Tools 15
PAUL161 Tools, Do We Need Them All? Restoration & Tools 12
aeronca65t Old tools = art Restoration & Tools 1
drooartz Tools needed to remove front & rear suspension Spridgets 24
Trevor Jessie Can't afford these tools, but I want to learn to use them Restoration & Tools 2
sail If you collect tools... Triumph 6
Gearhead Witworth tools Restoration & Tools 4
britlover Anyone in SE Michigan, or Northern Ohio with XJ 4.2 Cam removal tools to borrow? Jaguar 3
Banjo antique tools score Restoration & Tools 2
J knock, off tools Jaguar 6
S Tools valuation? Restoration & Tools 1
aeronca65t Sunbeam Tools Sunbeam (Rootes) 3
A Car Diagnositc Tools Restoration & Tools 4
Flash_Harry British Tools & Fasteners, LLC MG 1
RAC68 Convenient Homemade/Altered tools Austin Healey 18
Nunyas Pneumatic tools Restoration & Tools 8
M What tools can you see in this pic? Triumph 29
smaceng Eureka, all BE tools Spridgets 5
PAUL161 Chraftsman tools Restoration & Tools 13
W What tools for working on Healeys Austin Healey 17
I Picture of original bugeye tools? Spridgets 26
I Tools for tonneau fittings Austin Healey 8
5 tools for the LBC Restoration & Tools 20
Brosky Harbor Freight Tools New Years Day Special Triumph 5
AH3000MkIII BJ8 Factory Supplied tools Austin Healey 3
JPSmit Canadian Tire Tools on Sale Restoration & Tools 3
coldplugs Mystery tools Restoration & Tools 14
C Cheap place for tools, sjdiscounttools. Restoration & Tools 4
KVH Tinsters Tools--Front End Tools Triumph 1
JodyFKerr Tools & optional items Austin Healey 7
R Triumph tools Triumph 18
