zimmy
after removing and rebuilding
the master cylinder i reattached
it to the hose, filled it,(leaving
the cap off), then raised it high
as it would go and started SLOWLY
pumping it with my hand while
ROCKING it back and forth to get
the bubbles out..... next reinstall
after adding the cap!
hands down the easiest and least messy
way ive found to bleed the clutch!
everything is downhill and the bubble
"trap" is gone with the master in the air.
hope this helps some of those "mystery"
clutch problems!....drive on! ....zimmmmy
