bleeding clutch without results
bardunen
Fitted a new clutch master cylinder to a mini 1000 pre-verto yesterday, changed the hose to the slave cylinder, which is new, an tried to bleed the system. Nothing happens. The pedal stays to the floor, and no clutch oil comes from the bleeding screw. Could the fact that the clevis pins arent new (and that I have put a -thin- sound proof carpet under the pedal (ooops) be the source of my problems ? I mean, carpet and pins make me loose no more than a centimeter...
When bleeding with pressure bleeder, should the pedal be depressed or not ?
Thanks for your help :smile:
piman
Hello Bardunen,
if you mean the pedal stays depressed after you take your foot off then it shouldn't. Has the spring broken or is the pedal tight somewhere (misalignment?)?
The pedal should be up to use a pressure bleeder.
Let us know the answer to my first question and we can take it from there.
Alec /ubbthreads/images/graemlins/thirsty.gif
ThomP
That centimeter is important too. Purchase new clevis pins. The one at the pedal can be a pain to replace, but it is worth it; especially if you have added insulation under the carpet. Once you have solved the bleeding problem, if your clutch still doesn't operate as expected, the ball on the release bearing actuating lever is often worn. The best fix is to replace the arm with a new one.
Bleeding the hydraulic system is a two person operation. The bleed screw must be closed when the pedal is to the floor and ready for the "upstroke", otherwise, it will suck air back into the system and nothing will happen. The bleed screw then needs to be re-opened when the pedal is about to be depressed to be effective.
B
bardunen
thanks Piman and TomP. The pedal spring is okay, pedal returns its normal position by itself. I have carved away the soundproofing carpet, changed clevis pin...an adventure...and now I wait for a new bleeding screw, as it appears that the old one seems not to be really airtight... So now I m Waiting for a new one from minimania :smile: Fixing minis in sweden implies a lot of patience :smile:
B
bardunen
Bleeding completed at last ! Had to bleed the master cylinder first, it seems some air got trapped there. Even bleeded at the junction between the fixed and the flexible air lines. By the way Started by using an expensive vacuum bleeder without any result. A cheap pressure bleeder worked much better :smile:
ThomP
There's a MiniMania in Sweden? Surley you use MiniSpares in the UK?
B
bardunen
Well, as we have a 25 procent VAT in sweden, its kind of cheaper for me as a private person to buy from the US than from another EU country... as long as I get the thing shipped by mail, with no custom clearance, err...mmmhhh....
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
bugedd Bleeding clutch Spridgets 2
S Help with clutch bleeding on BJ8 Austin Healey 7
C Bleeding the hydraulic clutch Spridgets 6
H bleeding the clutch and not running Austin Healey 17
RickB MGB Trouble bleeding new clutch MC & slave MG 6
jlaird Brake and Clutch bleeding Spridgets 7
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RickB New clutch master - the expected bleeding nightmare has arrived Spridgets 16
RichBall Observations and impressions for bleeding the 1500 clutch system Spridgets 5
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
J Bleeding the clutch Austin Healey 23
F Bleeding clutch line Spridgets 12
D bleeding the clutch Austin Healey 5
B Bleeding clutch! Austin Healey 0
T TR6 TR6 clutch bleeding woes Triumph 28
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
Y BJ8 Clutch Master Cylinder Bleeding Procedure? Austin Healey 7
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
T Any tips on bleeding the clutch slave cylinder? Triumph 6
JPSmit Bleeping - I mean bleeding clutch Spridgets 15
eejay56 Clutch bleeding Triumph 18
zimmy my new clutch bleeding trick Spridgets 10
M Bleeding Clutch Spridgets 9
S Clutch bleeding problems Spridgets 19
B T-Series CLUTCH BLEEDING PROBLEMS MG 9
R Bleeding the Clutch Jaguar 5
jhorton3 Bleeding the clutch. Spridgets 21
G Bleeding the hydraulic clutch Spridgets 36
B T-Series clutch bleeding MG 8
vping T-Series Bleeding Clutch & ...... MG 34
zimmy bleeding new clutch hydraulics Spridgets 19
A Bleeding Clutch M.C. Triumph 3
P Clutch isn't bleeding... Austin Healey 8
J Clutch Bleeding Spridgets 9
G Bleeding clutch!!! Jaguar 10
G T-Series bleeding clutch sys ?'s MG 8
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
C TR2/3/3A bleeding brakes Triumph 11
KVH General Tech Bleeding Brakes—Venturi/Compressor Triumph 8
N Need brake bleeding advice Spridgets 6
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
