TRclassic3
Due to a caliper leaking I pulled and rebuilt the calipers (A type). When attempting to bleed kept getting lots of small bubbles from the same caliper that had originally been leaking. Using DOT 4 fluid. Went through some gyrations to determine if it was really leaking or just the result of messy bleeding. Have determined that it is leaking from same cylinder as original leak. But here is the odd thing: The brake can be pumped and held with no leak evident. Crack the bleeder and fluid drips off the bottom. Definitely not coming from bleeder or piping but from cylinder. Obviously have to redo that cylinder, but wondering if anyone has an explanation for the behavior.
Thanks
Thanks
