Hello Graham,
I have seen quite a few post here about problems bleeding clutches and I don't understand why.
I have bled clutches in the past by merely opening the bleed screw and letting gravity do the work (a bit slow though).
These days I use a pressure bleeder, but if you are using an assistant have him\her pump the pedal, (bleed screw closed) until there is a 'pedal'. Hold firm on the pedal while you open the screw, tighten then have the assistant raise the pedal and repeat until there is no air coming out of the bleed nipple. Just ensure that you don't allow the reservoir to get too low during this.
If this does not work and you can't get a firm pedal there is probably a master cylinder fault.
Also ensure the small flexible hose at the rear of the head is in good condition.
Viscosity of the fluid is, I think, irrelevant.
Alec
