90 XJ-S
OK, here’s the story as best I can remember it all.
I got my ’90 XJS Convertible about a month ago and have been driving it around enjoying the ride and the southern California sun. No real problems except that the transmission would not kickdown, the cruise control didn’t work and it never showed a “Fast idle” (always right on 750)
Last Sunday, after reading a post by Doug Dwyer about how easy it was to fix the kickdown problem
(“So, I did some exploring and discovered that the little round plastic throttle stop below the throttle pedal was adjustable. I screwed it inwards several turns. Now the kickdown *really* works.” DD)
I decided I would go fix that problem. I adjusted the little plastic thingy. Then I went exploring around under the bonnet and found the three-conductor plug going into the cruise bellows was partially disconnected. I seated it properly. Then while looking around some more I found one vacuum hose off the Vacuum Solenoid Valve. After hooking that back up I closed the hood and headed for the highway. (About a mile and a half, or so) After getting on the freeway and up to about 55 I went to WOT. The kickdown worked!! (I was suitably impressed. I instantly understood why I bought this black beauty. Then almost as instantly (I was up to about 80) the engine stumbled and coughed…twice. I grabbed the next exit…she seemed to be doing all right…so I turned her around and headed back. I tried setting the cruise at about 60MPH and it worked also!! But, once again, just as I was getting that “High” from something working right… she coughed again. From there on it ran fine, as long as I didn’t move the gas pedal. TPS pot my rookie brain said. So I took it home and checked the Pot ~.2 Volts. So I said Aha and adjusted it. Seemed touchy to me, but what do I know? Took it for a 100-foot cruise…still hesitates. So, after buying a new one of those (must be golden) pots… I installed it adjusted it (much easier this time…Set to exactly .320 Volts) No real change to the symptoms if anything, they got worse…didn’t really want to idle, considerably more sensitive to gas pedal movement. After fooling with re-breaking some of the things I fixed. With no improvements…it now doesn’t want to run at all. It will start and idle for around 1 – 2 seconds then die.
Does anyone have any words of wisdom for this bewildered Jaguar Novitiate?
TIA
Mike Smith
TIA
Mike Smith
