I am totally baffled and really need some help!
I have a recently acquired 79 MGB. 'B' starts and runs great as long as you don't shut it off and expect it to start again within the next 45mins or so.
I'm sure that it's flooding on restart attempt, but cannot figure out why. I have two temp guages and temp while driving stays about 185 Degrees, so it's not over heating. Carb is a single Z-S 175CDSE. The SE only has a manual choke and a temperature compensator. The floats are adjusted to spec, float needle valve is fine, temp compensator seems fine, no clogged holes in the carb, no bad gaskets, metering needle valve adjusted and looks good, air piston is not binding, diaphram is good, took choke apart and it looks fine, Vacuum to distributer disconnected and plugged at carb, hose to charcoal cannister plugged at carb, no smog pump, no gulp valve, all air holes on side of head plugged & I have good hot spark to the plugs. I blow gobs of smoke out tail pipe on restart attemt(raw gas) and the vent hole in the manual choke cover starts leaking gasoline. I have good vacumm but I'm beginning to think my vacuum is so good, it's somehow (when the engine is warmed up) sucking huge amounts of extra gas from the float bowl out though the choke and into the carb even though the choke is rotated off. One other thing I found out tonight, the only other hose not mentioned that's on the carb, goes to the EGR valve. I pulled the EGR and found that it has been purposely blocked off. I'm not sure if this will cause a problem or not, but I know that vacuum line from the carb is not doing anything.
ANY HELP WOULD BE GREATLY APPRECIATED.
