Loss of Power
carrottop
First run of the season. All was fine for the first 5 minutes and then lost most of the power and very rough running. Changed the rotor and checked the wires, which are new. Started running smooth and then the same thing. What should check next. I have a pertronix module which has been running perfectly. Could it be the carbs? Plugs?
Thanks,
Eric
TimK
Check choke (stuck on?)
C
carrottop
Don't think so. As this is a tri-carb, it has always been a pain to operate the choke, but it seems to go back to normal position once pushed in.
John Turney
I heard the Pertronix timing wheel under the rotor keeps the rotor from going down all the way. That causes the carbon center electrode in the cap to get mashed too far into the cap.
C
carrottop
Rotor is bottomed. Car ran perfectly all season last year without any sluggish loss of power. It is intermittent now. Thought it might be old gas but did filler up and no change.
C
carrottop
Tahoe,
I thought of that too. Checked and the needles went in more easily than in the past but didn't know if lack of oil could cause this problem. I'm told that 20 weight oil is recommended, right? Also, how do I avoid over filling?
Thanks,
Eric
Keoke
carrottop said:
Tahoe,
Idoubt it!!.
I'm told that 20 weight oil is recommended, right? Also, how do I avoid over filling?--Use a squirt type oil can..
Thanks,
Eric
Bottom line Module may be failing.--Keoke
C
carrottop
Keoke,
You sound like Dr. Doom. Do these these fail once operating? Thought they were pretty much fail proof.
Yuck,
Eric
RAC68
Hi Eric,
Are you running a fuel filter? Have you run your car over the winter or was it in stasis?
I suspect that your problem is fuel starvation caused by a blockage or a failing pump.
Sediment could have collected on your filters and/or screens and cause a partial block when running for a little while. At rest, gravity would allow the bits to drop and open the passage. When even partially open, fuel flow and pressure would build sufficiently to fill the carburetor’s bowls and allow for normal start and initial run.
Good Luck,
Ray (64BJ8P1)
C
carrottop
Ray,
Fuel Filter new last Spring. Car was in my garage all winter but did not run it but for a few start ups. Mechanical fuel pump ticking away as normal. Will check the filter for blockage.
Thanks,
Eric
Brinkerhoff
If you think its fuel, first take a fuel sample to see if you have water in the gas. You can also check delivery at the same time by pulling the crossover hose and letting the pump fill a jar.( with someone at the switch). You may also have one of the three float needles sticking shut not letting gas into the bowls. After you push the choke knob in make sure the jets go all the way up on the carbs.
fordtrucks4ever
I am thinking one of the carbs is not delivering fuel. Motor is totally lame with one of two carbs not supplying. I figure one of three carbs would be a little less obvious.
smaceng
I would drain the gasoline out of the tank, lines and the carbs, refill with fresh and try again. Modern gas does not like to sit over time and can create trouble.
Good luck,
Scott in CA.
Keoke
carrottop said:
Keoke,
Yep!! and they act similar to your problem right now. A cloged fuel filter is a good suggestion too.--Keoke
Yuck,
Eric
C
carrottop
OK. So after sitting in the garage for a week, I took my BT7 out for a spin. A little harder to start than usual, and slower clicks than normal from the fuel pump, but took her out after a long warm up and she ran like a top. No loss of power and smooth all the way. I did notice another fairly large amount of water vapor during warm up like last week and was thinking: since I had little fuel in her over the winter (my mistake), can there be a larger amount of water build up than with a fuel tank? Last week she ran rough before and after the fill up but maybe there was a build up of water in the fuel line that had to get worked out. Is this a reasonable explanation or am I just another mystified Healey owner?
Keoke
Tea it sound like you had water in the fuel system from someplace. Yes storing the car with a low amount of fuel in the tank allows more moisture to form than when it it full.--Keoke
Any opinion about StaBil (sorry for spelling) fuel stabilizer? I've used it for years over the winter. Always starts right up. I figure the ethanol in the gas would increase the water in the fuel and it would be more necessary to stabilize the fuel.
dougsmarkIII
I use the StaBil in my 66 BJ8 all the time. Plus my 64.5 Mustang convertible all the time. Both cars don't get driven lots of miles so the gasoline can get a little old. Also use it in powered equipment that gets stored for a season. I have a 22-year old lawnmower, a 20-year old string trimmer and a 6 or 7-year old snow thrower and a 30-year old leaf blower. They always start right up after storage. Nothing like having archival power equipment eh?
Doug
nevets
I'm totally unfamiliar with electronic ignition setups so please forgive my ignorance, but, I had some similar issues and the problem turned out to be a flaky coil. Seems that when it got warm, the coil would act up, which is why why the car ran well initially. Someone on this forum wiser than I provided the tip.
H Loss of Power Upon Acceleration Austin Healey 8
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
B Intermittent Loss of Electric Power Austin Healey 18
M Power Loss Austin Healey 27
M BN1 Loss of Power Austin Healey 21
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
M Engine power loss Austin Healey 4
D TR4/4A Sudden total loss of power Triumph 56
Lynn Kirkpatrick Hi RPM Power Loss MG 5
C Loss of power problem is back! Austin Healey 14
stretchit2 Loss of Power Too Austin Healey 14
C loss of power Austin Healey 24
Dudly Spitfire "79 Spitfire loss of power Triumph 7
S 1500 loss of power Spridgets 0
P power loss / bit of noise MG 13
H TR6 Late TR6 ; loss of power? Triumph 12
19_again intermittent power loss MG 0
MadRiver MGC MGC loss of power MG 10
RickB What would cause loss of all power [electrical] Spridgets 47
kennypinkerton Alfa Spider... Loss of power Other Cars 49
S TR6 TR6 Hesitation and power loss Triumph 1
G LOSS OF POWER WHEN TURNING RIGHT? MG 4
G Loss of Power MG 9
R Mystery loss of power Austin Healey 6
EWD TR6 Battery charge loss Triumph 25
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
R TR6 Evaporative loss system modification Triumph 5
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
R General Tech Loss of brakes Triumph 11
C TR4/4A Sudden loss of points gap Triumph 10
S Coolant Loss Spridgets 32
glemon General TR Weight Loss Program Triumph 9
RickB Our loss, our oldest son Josiah Bastedo. Spridgets 25
bertl Loss of Page Style FORUM Navigation Questions 0
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
E Getting a tach to work--im at a loss Austin Healey 2
T TR6 TR6 oil loss/usage Triumph 28
W My loss...your gain Spridgets 3
Stewart Machine gunning on acceleration, loss of spark MG 8
Morris Drivetrain loss Spridgets 5
tahoe healey Great loss to our community Austin Healey 14
B Loss of compression due to valve stuck open Austin Healey 2
Flash_Harry MGB-GT Coolant loss - '74 B-GT? MG 4
Jim_Gruber Mysterious Coolant Loss - Kim could this be yours Spridgets 2
G Healey Loss Austin Healey 4
D Mysterious clutch fluid loss Triumph 9
19_again T-Series loss of clutch after tranny install MG 16
D loss of cruise control Jaguar 2
T just read about Jack Drews-huge loss to us all Triumph 0
