    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Loss of Power
Well, next winter I will make sure 1) full tank of gas and required amount of Sta-Bil. The Chicago area is one the high end of the fuel price scale as we have 10% ethanol which I suspect contributes to the problem.
Thanks all.
dougsmarkIII said:
I use the StaBil in my 66 BJ8 all the time. Plus my 64.5 Mustang convertible all the time. Both cars don't get driven lots of miles so the gasoline can get a little old. Also use it in powered equipment that gets stored for a season. I have a 22-year old lawnmower, a 20-year old string trimmer and a 6 or 7-year old snow thrower and a 30-year old leaf blower. They always start right up after storage. Nothing like having archival power equipment eh?
Doug
Me too, stabil works ( my Honda mower is 23 years old)
nevets said:
I had some similar issues and the problem turned out to be a flaky coil. Seems that when it got warm, the coil would act up,
Yep, this is a strong possibility, I also had similar problem and it was a lousy connection on the low tension side between the coil and the dizzy, the wire into the terminal connection was shot and the car would start when cold but as soon as it warmed up it stopped.
I have also heard that a worn condenser in the dizzy could precipitate problems with the coil as well.
Just had another thaught, as soon as the car stops check the fuel flow to the carbs using an old soda bottle, if fuel still flows to the carbs, and if it is a fuel problem, check into the bottom of the float chambers for crud lying around, could just be dirt being dragged through the carbs and blocking the needles
Bob
H Loss of Power Upon Acceleration Austin Healey 8
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
B Intermittent Loss of Electric Power Austin Healey 18
M Power Loss Austin Healey 27
M BN1 Loss of Power Austin Healey 21
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
M Engine power loss Austin Healey 4
D TR4/4A Sudden total loss of power Triumph 56
Lynn Kirkpatrick Hi RPM Power Loss MG 5
C Loss of power problem is back! Austin Healey 14
stretchit2 Loss of Power Too Austin Healey 14
C loss of power Austin Healey 24
Dudly Spitfire "79 Spitfire loss of power Triumph 7
S 1500 loss of power Spridgets 0
P power loss / bit of noise MG 13
H TR6 Late TR6 ; loss of power? Triumph 12
19_again intermittent power loss MG 0
MadRiver MGC MGC loss of power MG 10
RickB What would cause loss of all power [electrical] Spridgets 47
kennypinkerton Alfa Spider... Loss of power Other Cars 49
S TR6 TR6 Hesitation and power loss Triumph 1
G LOSS OF POWER WHEN TURNING RIGHT? MG 4
G Loss of Power MG 9
R Mystery loss of power Austin Healey 6
EWD TR6 Battery charge loss Triumph 25
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
R TR6 Evaporative loss system modification Triumph 5
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
R General Tech Loss of brakes Triumph 11
C TR4/4A Sudden loss of points gap Triumph 10
S Coolant Loss Spridgets 32
glemon General TR Weight Loss Program Triumph 9
RickB Our loss, our oldest son Josiah Bastedo. Spridgets 25
bertl Loss of Page Style FORUM Navigation Questions 0
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
E Getting a tach to work--im at a loss Austin Healey 2
T TR6 TR6 oil loss/usage Triumph 28
W My loss...your gain Spridgets 3
Stewart Machine gunning on acceleration, loss of spark MG 8
Morris Drivetrain loss Spridgets 5
tahoe healey Great loss to our community Austin Healey 14
B Loss of compression due to valve stuck open Austin Healey 2
Flash_Harry MGB-GT Coolant loss - '74 B-GT? MG 4
Jim_Gruber Mysterious Coolant Loss - Kim could this be yours Spridgets 2
G Healey Loss Austin Healey 4
D Mysterious clutch fluid loss Triumph 9
19_again T-Series loss of clutch after tranny install MG 16
D loss of cruise control Jaguar 2
T just read about Jack Drews-huge loss to us all Triumph 0
