loss of cruise control
doxjag
My 98 XJ8 cruise control will disengage when the engine is not
pulling - such as at the top of a hill. It then has no memory when
I try to resume the speed. It will stay engaged as long as I'm
going uphill, even for miles. Then it never fails to turn off when
I coast or let off throttle. Any ideas? Thanks.
These fault codes may not be related: P1227, P1643
Deleted member 8987
I haven't dealt with cruise controls for at least 10 years, but, since there are literally DOZENS of types, here goes my limited knowledge:
The "Resume" button is bad or dirty.
If mounted on the end of the T/S switch, it can even be the small wires that go from the T/S arm down the column.
If steering whel spoke mounted, clean the switch and the slip rings.
Some depend on specific resistance changes to operate, and dirty slip rings/brushes can do that.
Fuses. Some have 2 power feeds, unswitched battery and ignition.
Sometimes, some functions won't work if one supply is bad (but generally other things will not work at the same time).
If someone has done any electrical work of late, especially anything to do with aftermarket raio, IPods, handless cell phones, sometimes folks probe a wire looking for power and get what they think is what they want, and it's a load sensitive cruise control line.
H Loss of Power Upon Acceleration Austin Healey 8
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
EWD TR6 Battery charge loss Triumph 25
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
B Intermittent Loss of Electric Power Austin Healey 18
M Power Loss Austin Healey 27
R TR6 Evaporative loss system modification Triumph 5
M BN1 Loss of Power Austin Healey 21
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
R General Tech Loss of brakes Triumph 11
C TR4/4A Sudden loss of points gap Triumph 10
S Coolant Loss Spridgets 32
glemon General TR Weight Loss Program Triumph 9
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
RickB Our loss, our oldest son Josiah Bastedo. Spridgets 25
M Engine power loss Austin Healey 4
D TR4/4A Sudden total loss of power Triumph 56
bertl Loss of Page Style FORUM Navigation Questions 0
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
E Getting a tach to work--im at a loss Austin Healey 2
Lynn Kirkpatrick Hi RPM Power Loss MG 5
C Loss of power problem is back! Austin Healey 14
T TR6 TR6 oil loss/usage Triumph 28
C Loss of Power Austin Healey 22
W My loss...your gain Spridgets 3
stretchit2 Loss of Power Too Austin Healey 14
C loss of power Austin Healey 24
Stewart Machine gunning on acceleration, loss of spark MG 8
Morris Drivetrain loss Spridgets 5
tahoe healey Great loss to our community Austin Healey 14
B Loss of compression due to valve stuck open Austin Healey 2
Flash_Harry MGB-GT Coolant loss - '74 B-GT? MG 4
Dudly Spitfire "79 Spitfire loss of power Triumph 7
Jim_Gruber Mysterious Coolant Loss - Kim could this be yours Spridgets 2
G Healey Loss Austin Healey 4
S 1500 loss of power Spridgets 0
D Mysterious clutch fluid loss Triumph 9
19_again T-Series loss of clutch after tranny install MG 16
P power loss / bit of noise MG 13
T just read about Jack Drews-huge loss to us all Triumph 0
R restricted connections in fuel evap. loss system? Spridgets 13
H TR6 Late TR6 ; loss of power? Triumph 12
bill_young Loss of great LBC supporter. MG 1
ArtQ Coolant Loss Austin Healey 38
19_again intermittent power loss MG 0
2wrench Re: Screw at engine front stopping oil loss Triumph 8
MadRiver MGC MGC loss of power MG 10
A Coolant loss MG 21
jlaird I'm at a loss Spridgets 13
