dklawson said:
Use caution when installing coils with the SW and CB labeled terminals. They were used most commonly on the older positive ground installations. You're supposed to reverse these coil connections if you convert the car to negative ground. According to others on this forum, failure to swap the coil terminals when switching to negative ground will result in a significant reduction of the available spark voltage. Ping Dave Russell for details.
This is another one of those things in the conventional wisdom that puzzles me. I have also read, in one place or another, that ionization in the plug gap occurs more easily with one polarization, so the voltage needed to fire the plug is about 15% lower. The fact that the coil's primary terminals are marked (the CB and SW labels) lends credence to this idea, but I can't imagine why it would be true. Indeed, in Astley's book,
MG Electrical Systems, the section on positive-to-negative ground conversion doesn't mention it.
The only other reason I can see for marking the coil primary terminals is that the bottom end of the secondary coil is connected to the CB terminal, the one that goes to the points. So, in normal operation, the secondary current goes to ground through the capacitor. If you reverse the terminals, the ground return is now through the electrical system. The current is pretty small, so it probably doesn't matter; but, if anything, it implies that you should NOT switch coil terminals.
If you do switch the terminals, you might get more electrical noise in the system, which might affect radios or other modern electrical components. To avoid this, add a 0.25 uF, 500V capacitor to the CB terminal (which is now connected to the switched 12V power, not the points). It won't affect performance, but might reduce electrical noise.
