TR2/3/3A Back to my ignition coil education
Lukens
I stated previously that my 3.0 ohm coil failed recently. I replaced it with a 1.4 ohm coil. It may be my imagination, but the car seems to fire up a little quicker (with the full 12 volts to coil). I understand that many earlier cars had full voltage to the coil in "start" mode, but reduced voltage in "run" mode. I've placed a 1.5 ohm resistor in the "key on" wire to the coil. Would there be any real advantage to running a parallel wire from my starter button to the coil? Over thinking?
Russ
TR3driver
Great Pumpkin - R.I.P
No reason you can't try, if you want. Note that you need a diode or relay, though, as otherwise the solenoid will be shorting out the coil when you release the button.
It was actually later cars (TR6 started in 1973) that used the external ballast and shorted it out during starting. Mostly an emissions thing, IMO, as the emission controls during that period made them harder to start. But it was pretty much the standard configuration until electronic ignition with adaptive dwell took over; which is why FLAPS generally only have the 1.5 ohm coils. My Stag had it originally, but when the wire broke I just left it disconnected. Couldn't tell any difference, but I've never tried starting it in below freezing weather (when it's needed the most).
Lukens
Lukens
Yes, I just realized the starter solenoid would be energized as long as the key is on. I think I'll leave well enough alone.
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
Y MGB 1977 MGB Ignition Coil and Wiring. MG 5
TulsaFred Ignition / Ignition coil problem Spridgets 10
M ignition coil high tension lead connection Spridgets 10
CJD TR2/3/3A "Big" ignition coil Triumph 12
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
Mowgli81 Starting Problem Ignition coil? Dist. Cap? Austin Healey 21
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
NutmegCT Ignition coil resistance Triumph 8
S Lucas Sport ignition coil Triumph 29
A TR2/3/3A WHAT IGNITION COIL TO BUY FOR MY 59 TR3 Triumph 10
C Ignition coil question Triumph 4
I Bugeye ignition coil wire help Spridgets 7
G Lost spark [ Best ignition coil for a stock '79] Spridgets 18
A TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
T overheated ignition coil ? Triumph 21
MGTF1250Dave Ignition Coil Low Tension Connections Triumph 12
R spark plug gap with pertronix ignition and coil Spridgets 6
B Ignition Coil Mounting Spridgets 6
S Ignition, coil recommendations? Spridgets 9
eschneider ignition coil oil ? Triumph 11
8 IGNITION COIL Triumph 1
V TR6 TR6 ignition coil polarity Triumph 3
VictorVictor ignition coil Spridgets 17
martx-5 TR2/3/3A TR3 Ignition Coil Triumph 5
zimmy Pertronix coil and ignition system Spridgets 8
Editor_Reid Ignition Coil Nomenclature Austin Healey 7
ronzet AH 100-6 Ignition coil polarity POSITIVE EARTH Austin Healey 15
jsneddon Ignition Coil Wiring Triumph 2
G Ignition / Coil Wiring Question MG 12
AUSMHLY Pertronix ignition and coil Austin Healey 4
G TR5/TR250 TR250/6 ignition coil Triumph 5
Cain Short in Ignition Coil? Triumph 5
O Ignition switch / steering lock replacement in a '78 midget Spridgets 4
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
S Ignition advance weights - how to lube? Austin Healey 5
K TR2/3/3A Ignition Timing? Triumph 11
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
WJKB-TR6 TR6 Ignition Switch-73TR6 Triumph 5
S 58 Bugeye Ignition/Light Switch Spridgets 1
S 58 Bugeye Ignition/Light Switch FORUM Help 4
