I figured out that my ignition coil was bad so now I need a replacement recommendation. All is stock on the car. I replaced my original Lucas coil with a coil I had laying around which says 12 volt and "use with primary resistance wire or external resistor", but I do not know if this will be OK or not, and thus I want to order a new one. Should I get the standard coil as listed in the catalogs, or the Sport Coil, or what? Thanks ........AL
