How Much Oil
spooch22
How much oil do I use for an oil change without a filter change? I have a 70' TR6, stock engine.Which oil do you use and/or recommend? Thanks /ubbthreads/images/graemlins/patriot.gif
Musicman
Between 4 and 5 quarts. It's usually 5 quarts with the filter change. Just put 4 quarts in and check it before adding anymore. I just put some Valvoline 10w-40 in my 75 TR6. There are lots of choices when it comes to oil selection. I'm sure others will chime in with advice as well.
achtungeveryone
My oil selection is 10w40. It is Castrol brand which I choose because of it's cool looking bottle. I add a dash of vanilla but I'm not sure what that does other than kind of smell good. The manual actually states 9.64 pints! Pint's are ok but I like the quarts myself...about 4 and a half or so...
Actung
myspitfire
Briggs&Stratton makes neat lawn mower engine oil changer.Just hook it up to a cordless drill & off you go.Change the oil from the top.:smile:
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
richie TR4/4A How much oil is normal.. Triumph 6
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
V How much extra engine oil with oil cooler??? Spridgets 5
6 too much oil pressure??? Triumph 25
RJS Oil and Filter Change [how much oil?] Triumph 2
DarwinT How much oil in the tranny? Spridgets 6
T How much dashpot oil leakage is normal Triumph 14
N How much oil should an engine use on break in Triumph 20
B How much oil when you have an oil cooler? Triumph 4
mylillooker Oil, ...how much? What kind? Spridgets 2
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
drooartz How much fender beading for Bugeye? Spridgets 17
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
