GTP1960
I probably have created my on problem, but before I take it into the "real guy" I would appreciate opinions.
Background:
just getting it back on the road after replacing crank fan with dampened narrow belt pulley ( losing TDC mark in process.) though I did mark the new pulley based on the old ones position , I can't spot my mark with a timing light.
So I'm pretty much just setting the timing by ear and feel.
new petronix flame thrower III distributor & 45k coil
new facet electric fuel pump.
(fresh 93 pure gas)
starts right up & idles smoothly.
(i have the idle set at about 1000.)
bumps a little while revving.
hesitates & lurches slightly during acceleration while running thru the gears, but once up to running RPM /speed, seems to run well.
Any opinions & advice appreciated.
Background:
(fresh 93 pure gas)
