Backfire during decelleration
ron wilson
I have a74 MGB that backfires a lot during decelleration. Is this a sign that the mixture is too rich. Mufflers are shot also.
dklawson
As mentioned, you have an exhaust leak. Don't limit your search for it by looking at the muffler. Look for perforations in the pipes, leaks at the pipe joints, and the flanges to the cylinder head. It's amazing how sealing all those minute leaks can make backfiring on decel go away.
vping
Bronze
Say your system was intact without holes. Might you get some backfiring during deceleration?
77v8
Had the same problem as you, turned out to be the gulp valve was bad.Do you still have the smog stuff on?
Billm
Yep- mine was the gulp valve too. Finished removing ALL of the smog stuff and the backfiring stopped.
Bill
Nunyas
problem solved! a leak inna exhaust! NEXT! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Platinum
Now we can completely divert THIS thread! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Nunyas
i painted a wheel today...
Deleted member 3577
I'm considering replacing my analog Lucas flasher relay with a solid state look alike....
Will this psychologically damage my car's ego?
Nunyas
I'm not sure... would you take an ego hit if you had a pace maker installed? /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
Platinum
Voluntarily?
...I think not. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
Deleted member 3577
Maybe I would if someone told me I needed to wear new makeup /bcforum/images/%%GRAEMLIN_URL%%/whistle.gif .
K TR2/3/3A Missfire and Backfire Triumph 141
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
J Backfire through carbs Austin Healey 3
K Midget backfire at intake side... Spridgets 7
M TR6 1975 TR6 Backfire from Carbs, running Lean - Help! Triumph 9
tinman58 TR2/3/3A Backfire! Triumph 13
T Spitfire Backfire Triumph 1
D Carburetor Backfire on acceleration at low speed Austin Healey 18
H Backfire on deceleration MG 6
D BT7 Tri carb Backfire Austin Healey 2
Jim_Gruber Sputter, miss, backfire, Yuck!!!! Spridgets 27
roofman Spitfire Spitfire backfire, timing or carb? Triumph 12
JPSmit tonight - backfire Spridgets 10
T What causes an engine to backfire? Triumph 15
G Engine Backfire Austin Healey 13
J MGB 1976 mgb backfire MG 5
D MGA mga start and backfire MG 5
R backfire...ect. Austin Healey 50
SilentUnicorn Backfire question Other Cars 11
jerrybny My clunk is gone too and Backfire question Triumph 10
73MidgetLigon mg backfire dcoe Spridgets 31
A TR4/4A TR4A backfire - help please Triumph 15
S Backfire through rear carburator Austin Healey 18
B TR4/4A Tr4A carb. backfire Triumph 3
S Wedge Finally! I figured-out the TR7 backfire problem!!! Triumph 3
S Wedge Help in solving TR7 lift-off backfire Triumph 9
M Help with backfire and smoke Triumph 2
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
T supporting BE tonneau cover during heavy rains Spridgets 10
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
GTP1960 TR2/3/3A Hesitation during acceleration Triumph 13
charleyf TR2/3/3A Front suspension lubrication during assembly Triumph 4
M XK140 Roadster Body supporting methods during Removal Process Jaguar 1
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
K Location of most Triumphs sold during their heyday? Triumph 15
R Sprite misses during acceleration Spridgets 7
SkinnedKnuckles Great Rants/Questions During Golf Triumph 18
CraigCootsona Wiper motor quit during last run Spridgets 9
F Chassis flex during panel replacement Austin Healey 7
R Insurance during restore Austin Healey 6
doughairfield Oil during engine break in Triumph 6
RJS Engine Bay Protection During Winter Storage Triumph 8
vping Winsheild problems during replacement MG 1
74WannaB protecting metal during restoration Restoration & Tools 9
jlaird During my Carb adventure Spridgets 3
mbrooks Battery charging during storage Austin Healey 5
A Revs don't fall during shifts MG 8
