jhorton3
Any time I stomp the gas pedal the engine has a severe hesitation in throttle response. The engine stumbles, looses a couple hundred RPM. If I keep my foot on the gas the revs eventually climb after 20 seconds and it smooths out a little around 3,000 RPM. This happens if the car is standing still or moving.
Distributor (25d) rebuilt unit from local parts store. New cap, rotor, points, condenser, and coil. I've swapped condensers and coil with same results. This has been a problem for quite some time. Last weekend I put the timing back to static timing. Adjusting the timing helps slightly, but not enough.
I've got 2 SU HS2 carbs that were rebuilt units I purchased. The jet adjusting nut is down about 12 flats. This happens with or without air cleaners. I put 20/50 motor oil in the dashpots. I've got a clear glass fuel filter showing clear supply of fuel. This also has a square body fuel pump (Facet) that runs all the time no matter what.
Plugs and wires are Autolite brand. Plugs are gapped .25. Points are gapped .016.
So what have I overlooked? I'm planning on trying to solve this problem this weekend. Could it be carbs are too rich/lean? Another timing issue? I've considered getting a Pertronix Ignitor unit, but not sure it would really solve anything.
