supporting BE tonneau cover during heavy rains
twas_brillig
Our tonneau settles under the weight of the water during a rainstorm, tugging the 'sides' away from the doors. I expect that it has stretched a bit over the years and will continue stretching until such time as water will start flowing over the edge of the tonneau and down the insides of the doors. Any suggestions as to approaches to supporting the tonneau so less water accumulates? Thanks, Doug
X2
Bill’s advice easiest and simplest.
Found a (approximate) 20 inch dia/64" circumference exercise ball in the basement and it does the trick; still need to pick up a twin for the second seat.
I bought a couple of 16 inch beach balls and they were too small; will try putting some scrap foam rubber on the seat to see if I can space the 16 inch up enough, as a quick search didn't turn up any 20" inflatable beach balls locally, and the dang exercise balls are a lot bulkier when it comes time to store them. Doug
IIRC there was a 2 piece tubular bar that slipped into the sockets right behind the seats (where the top bows fit) that supported the cover at that point. It also allowed the cover to be taken off the seat area, draped over the bar and attached to the bulkhead behind the seats when driving. This might be Moss part numbers 453-605 and 453-635 but I would think something similar could be fabricated for a lot less money.
I'm not sure, but if the bugeye has the sockets on each side for the top frame I'd certainly look at fabricating some kind of bow. Perhaps electrical conduit or pvc pipe & fittings. Even if it doesn't have the sockets I think I would still prefer a little fabrication time over a pair of beach balls, just looks more professional.
The cockpit on the non-BE Spridgets is longer than our BE, so presumably would benefit from an additional support. Our cockpit ends right behind the seats - the exercise ball looks like the best equivalent to the later series tonneau support. Now, if someone also has suggestions to keep water getting under the edges or through the zipper, t'would be appreciated. We had a lot rain up until a week back, and she's a wee bit dampish inside. Doug
Is there a way to add a snap or two on each side, perhaps splitting the run into thirds which would help keep it taut? Or, at the risk of stating the obvious, don't park it in the rain.
I like the 'don't park it in the rain'. I'd rather not change anything on the body. One thing I'd been thinking originally was just to cut a piece of 1x6 to an appropriate length and slip it in under the tonneau and rest it on the tops of the doors.
I took a 16 inch beach ball and two chunks of foam rubber, maybe 3.5" thick each, and put them all on the driver's seat this evening and it looks good (so to speak). There's a chance of a thunderstorm tonight or tomorrow evening, so a chance to test. Also sprayed the zipper with a silicone spray to help keep it slidin'; doubt if there's any waterproofing involved.
The foam is two chunks that I'd cut to roughly the size of the seat cushions in the past, to provide a bit more cushioning for long rides. Doug
zedvictor1 Where can I find the supporting vendors? FORUM Navigation Questions 1
M XK140 Roadster Body supporting methods during Removal Process Jaguar 1
aseriesspares New Supporting Vendor, Introduction and Discounts! Triumph 13
aseriesspares New Supporting Vendor, Introduction and Discounts! Spridgets 19
aseriesspares New Supporting Vendor, Introduction and Discounts! British Motor Corp 0
aseriesspares New Supporting Vendor, Introduction and Discounts! MG 10
aseriesspares New Supporting Vendor, Introduction and Discounts! Austin Healey 7
Jim_Gruber Oil Cooler Hoses - Routing and supporting Spridgets 10
tony barnhill Supporting Vendor Forum Spridgets 0
tony barnhill Supporting Vendor Forum MG 4
J Supporting car w/o suspension? Austin Healey 8
Basil New Healey Supporting Vendor Austin Healey 23
Celtic 77 MGB Tonneau info MG 3
T Avoiding Water Puddling on Tonneau Austin Healey 4
Popeye TR4/4A Tonneau or top cover? Triumph 12
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
Celtic 77 Wanted Tonneau MG Classifieds 4
R For Sale TR6 TONNEAU COVER ( FACTORY ORIGINAL ) Triumph Classifieds 4
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
pbraun Bugeye tonneau pattern Spridgets 1
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
M For Sale BJ8 Tonneau Cover Austin Healey Classifieds 8
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
Upland Tonneau cover repair Spridgets 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
jackq MGB New tonneau cover in box MG 1
A TR2/3/3A Pegs-top and tonneau Triumph 3
L Wanted WTB: Bugeye tonneau cover with roll bar cutouts Spridgets Classified 0
I For Sale TR6 tonneau cover Triumph Classifieds 5
Hangtown Healey BJ8 tonneau cover bag Austin Healey 6
T Securing the Tonneau on a 3000 MkII Austin Healey 4
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
J Wanted WTB: TR3a top and Tonneau Triumph Classifieds 2
CessnaTPA Tonneau Install Question Austin Healey 13
H Tonneau cover Austin Healey 2
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
K For Sale TR4A tonneau cover.... Triumph Classifieds 3
Keith_M bugeye tonneau fittings Spridgets 11
K TR2/3/3A Tonneau capping mounting questions.... Triumph 2
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
vette BJ7 Tonneau Cover Austin Healey 10
RickB MGB Any deals for a new Tonneau cover? MG 8
Tinkerman TR2/3/3A 1960 TR3A Tonneau Capping Installation Triumph 1
Tinkerman TR2/3/3A 1960 TR3A Tonneau Trim Mill board Triumph 10
