Help with Diff
tomgt6
What diff would you use on a Spitfire with a 1300cc engine and a 4 speed tranny.
Will be driven around town with very little highway driving and most highway driving will be within 15 miles.
Would you use a 4.11 or a 3.89 and then why?
V
vagt6
This heavily depends on how you're gonna drive the car. Do you like hole shots? Are you looking for more "oomph" from dead starts? Do you drive agresively? Then go for the 4.11.
But for driveability, I vote for the 3.89. A 4.11 is a very geary ratio IMHO. With the 3.89 your revs should be somewhere in the high 3000s at about 60, and give you all the grunt you need around town.
The 4.11 makes any kind of highway speeds VERY revvy.
To each his own, but for casual, around town driving and occasional highway jaunts, I'd go with the 3.89.
Andrew Mace
At 60 mph, the difference between a 4.11 (3820 RPM) and a 3.89 (3600 RPM) isn't very much. One other factor to consider is that a 3.89:1 diff complete will require you to change the u-joint flanges on your propeller shaft and axle shafts to the larger size, and you'll only have four studs to hold down your leaf spring (not really a problem). If you get a 4.11 diff (or already have one), odds are it's the older style with the smaller flanges as original on your Spitfire. Otherwise, either will bolt right up to the chassis.
Remember, the Mk3 Spitfire came with the "small journal" 1300 and a 4.11 diff, while the early MkIV had the "large journal" (and single Stromberg) 1300 and a 3.89 diff (ignoring, for the moment, the 1972 "Federal" Spitfire with its low compression 1300 engine and a reversion to a 4.11 ratio but in the newer case with larger flanges).
There's a chart on my web site showing various gearbox and differential ratios for most of the Triumph "small car" lines.
Darwin GT6 Diff Help Please Triumph 2
Willie_P rear diff crownwheel help Triumph 3
M Help to the newbie - Diff Whine Austin Healey 16
JPSmit Help #3 - diff + half shafts now Spridgets 2
B TR6 Help! TR6 Diff Mounts - poly or rubber? Triumph 12
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
