Help, What goes here?
AweMan
This is a pic of the right side bulkhead on my 56 Tr-3 What goes in or over this hole?
Another view.
View is from the inside where you feet go when you are seated. looking toward the fender {wing} forward of the door.
Kerry
MGTF1250Dave
Aloha Kerry,
I would assume a speaker for a radio. My son's '58 TR3A has the same type of hole there. On his car the hole is very well finished and must have been factory cut, or perhaps on arrival in the US for a optional radio install.
I'm sure someone will have a definitive answer.
kodanja
looks very much like a speaker cut out
AweMan
AweMan
It`s a pretty good sized hole, 6 & 3/4 dia. Looking through that hole what you see is the inside of the right front fender. I would think a speaker there would stand a good possibility of getting wet. I didn`t take that part of the car apart so I have no clue how it is supposed to be! AND I have nothing in my parts pile that apperas to fit in or over the hole.
I guess if no one has a better idea, I will manufacture a cover and rubber gasket then bolt it on to cover the hole up.
I plan to have an upholstery piece made to go on the bulkhead sides and don`t want them getting wet.
BTW there is NO hole on the left side.
PeterK
Same hole on mine too. I always thought it was for a speaker too but it's very large. Just the interior panel covers over the hole; some cars just have a cover with a carpet piece but mine has a vinyl covered hardboard piece. I've never had moisture that far up since it's behind the fender baffle plate and seal anyway.
toysrrus
Hi There AweMan;
Man; That is a Big Hole! It obviously must be a speaker hole but the Depth is next to nothing: Meaning; If you did mount a relatively Flat Speaker, Would`nt you have to Re-Cut another Hole for the Magnet to pass thru in the Inner Wall of the Wing? Quite suseptable to the Elements; don`t you think! No hole on the other side; "Strange"???
Just driving thru;
Have Fun; Russ
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
