Electrial issues...where to start
Whitephrog
Hadn't had the Whitephrog out in several months. Decided it was time for a spin. Turned the key to start expecting to hear the putt, putt, putt from the fuel pump.....nothing. Checked horn, lights, etc....nothing. Took the battery (nearly new Bosch) to Autozone they confirmed that the battery was good and gave it a full charge. Put the battery back in. Turn the key to start....nothing. No fuel pump putting, no lights, etc. I really hate fooling with electric stuff but have no choice in this case. Where do I start? What is a logical sequence?
Post Script: I went out this morning....reconnected the battery...turned the key to start...still nothing until I pulled the wiper switch. They horn blew!! Turned the key to off...pulled the wiper switch...the horn blew!!
BlueMax
Ray, I would start with the main ground cable off the battery where it attaches to the fire wall. I would remove it and lightly sand both the body and the flat connector. Grounds are a Sprites worst enemy.
drooartz
First suggestion is to check all the electrical connections for good, solid connections. Pay close attention the grounds as well. The horn push should ground the horn, causing the beep -- if the wiper switch beeps the horn then somehow it's making the ground for the horn. Might be a loose wire behind the dash.
Luckily a Bugeye doesn't have all that many wires to begin with.
smaceng
Ray, if you have a 12V test light, or an voltmeter, put the test leads across the battery terminals. Should get a reading of 12V or light the light. Then move the ground lead to a good ground on the body....should get a reading. Then move the power lead to the battery connection on the starter solenoid. should get a reading. the horn is hot all the time, so put the power lead to the hot side of the horn fuse.....etc.....get the idea?
Scott in CA
hondo402000 New dash complete, now electrial problems Triumph 17
Deanrobert Xke series lll cooling issues Jaguar 5
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
drustom fueling issues Restoration & Tools 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
Celtic 77 MGB 77 Stromberg issues MG 12
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Celtic 77 MOSS response issues Restoration & Tools 11
A Spitfire Spitfire Fuel pump issues Triumph 5
Celtic 77 MGB 1977 MGB Brake issues MG 8
I Bugeye charging issues Spridgets 8
K TR2/3/3A TR-3B carburator issues Triumph 2
T TR6 Continuous Starting and Ignition Issues Triumph 6
E MGB MG Idle issues, restart issues solved. MG 4
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
J Wiring Harnesses Issues Spridgets 3
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A TR3A electrical issues Triumph 2
R TR6 1973 Final drive issues Triumph 5
G 79 Midget Clutch issues Spridgets 9
Dnickels Spitfire Spitfire lighting issues Triumph 4
I TR6 Dash light issues Triumph 19
Rob Dodge Trafficator arm issues. Jaguar 2
M 1972 Midget Engine Issues Spridgets 10
R TR6 Gearbox rebuild issues Triumph 8
A Front wheel bearing issues Austin Healey 11
T 100-6 start up issues Austin Healey 6
N Electrical Issues Need Help Austin Healey 8
sundown TR6 Fuel issues Triumph 5
R TR6 Clutch issues Triumph 7
K TR2/3/3A Up-date TRF points issues resolved. Triumph 0
K TR2/3/3A Friends TR3 has carb issues? Triumph 5
N TR6 Electrical Issues Triumph 5
FlyingCat Spitfire Clutch Issues Triumph 8
F TR6 Carburetor issues at low rpms webers Triumph 23
S TR2/3/3A Wet liner issues Triumph 6
R BN7 Speedometer issues Austin Healey 1
steveg Steering rebuild followup - still issues Austin Healey 29
2 TR2/3/3A Coil issues Triumph 31
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
Joe Reed General MG MG Driver back issues....FREE! Anyone want them? MG 4
bighealeysource Turn signal issues Austin Healey 6
D Healey 100 issues Austin Healey 15
S TR2/3/3A Overdrive Solenoid Issues Triumph 11
TEM666666 Sprite Chrome Hubcap Fitment Issues? Spridgets 4
B TR6 Starter Issues Triumph 7
