Hi,
So, I've got a few questions about the early BN4 top. First concerns the strapping. I've seen cars that have the strapping fitted just between the two rearmost top bows. But, I've also seen cars with strapping fitted to the two rearmost bows, then laying over the front bow, and them onward to the header rail. So what is correct? And, related, is it correct that the strapping is attached to the underside of the two rear bows, and does not go over the top of those two bows? The top frame I have is missing the strapping, but has the little clamping plates on the undersides of the two rearmost bows. Also, if the strapping does go up to the header rail, how is it attached up there? Does it go over the top of the wood bow (vinyl covered), then curve back under the wood bow between the bow and the aluminum plate that is fitted along the bottom of the wood bow? Lastly, where does the actual fastening of the top material get fastened to the header rail? Is it tacked on the underside or is it tacked along the front edge, and then the tacks covered by the strip on the front edge that gets those little chome end caps? Details, details. details......
Andrea Villa - your page with the photos of the convertible top assembly of your BN4 are great!! Thanks so much for having that page!
- Paul B.
BN4L/35517
- Paul B.
BN4L/35517
