Cooling Article
BobbyD
Cross Post: For those of you not on the Triumph Mail List, the link https://www.teae.org/cooling/cooling_article.html to this cooling article was posted by one of the List members. While the study was done on Sunbeams and focused on how to improve their cooling while at IDLE (these poor guys overheat after idling about 10 minutes) , it delivered some interesting & surprising results e.g. pushers worked best, less fat blades worked better then many thin blades, stock radiators and stock water pumps worked just fine, shrouds are critical etc.
Trick6
I share with the thread my experience as follows.
I have installed the PeraCool 16" fan as Dan Masters recommended. I followed this to the letter. The thermostat control switch is located in a "Tee" fitting at the top radiator hose. I do not have an override switch and have not needed it. The radiator is the stock unit which is just fine.
The temp gauge spends most of its time in the area 1/8 inch right of cold. The fan comes on at just shy of half way and only in stalled traffic. When I pause in the drive way to open the garage door the fans comes on and after a very short time is off. I have heard fans other than the PermaCool run much longer.
I have the 55amp GM alternator conversion which puts quite a load (about 400 rpm drop) on the motor at idle when the fan is activated.
This works for me.
philman
I like it. Thanks, I'm printing it out for my reference library.
BobbyD
BobbyD
Al... mine performs pretty much like yours with a couple of exceptions: When the Spal thermostat turns the fan on, the fan runs until it drops the temperature something like 10 degrees below it's engagement point. Usually you never notice it because it happens in traffic but it's pretty obvious when you have the car parked. I've never noticed an RPM drop when the fan is running......the fan's electric so there's no load on the engine and the alternator doesn't turn any differently when the fan comes on. Usually people with marginal alternators or electric systems will see a voltage drop on their gauge as electric things come on.
What time you leaving for Stowe?
Geo Hahn
BobbyD said:
...surprising results e.g. pushers worked best...
Did they test pullers (other than crankshaft mounted fans)?
As Sam Goldwyn once said "I read part of it all the way through" so I may have missed that.
Trick6
The rpm drop when the fan comes on is noticeable. The fan is advertised to draw 8.9 amps. I have the fan running on a dedicated circuit with a 30 amp fuse. I thought that the 55amp GM alternator would take care of the electric fan and fuel pump.
I believe that when every there is a load placed on the altenator, the engine is taxed to turn it. It is like having a hand drill turning and you trying to stop it by hand. You hear the drill motor working to over come the resistance placed on it. RPM drop.
Bob, I believe that your upgraded wiring harness might make a huge difference. Better and larger wires, less resistance. Wire composition/size/resistance equations is another discussion.
Here is the fan that I used.
https://www.jegs.com/i/Perma-Cool/771/19126/10002/-1
Here is the Dan Masters article.
https://www.hottr6.com/triumph/tr6fan.html
2wrench
Copied the info, Al, in case I ever decide to go there. Everything
being rebuilt, so thought I'd give stock a chance to satisfy me,
but 6 owners seem to like this upgrade for a reason.
Mark Jones
They never tested the same fan in puller mode. If they had they would have found it to better than in pusher mode. Drawing air through a radiator is mode efficient than trying to push it through.
Deanrobert Xke series lll cooling issues Jaguar 5
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A Water pumps/head cooling Triumph 22
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
steveg TR6 Cooling system filling Triumph 7
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D BT7 air ducting / cooling Austin Healey 20
D Trying to understand my cooling system Austin Healey 29
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
7 stupid plastic cooling system parts Other Cars 2
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
steveg Definitive results of tests on factors influencing cooling Austin Healey 46
T TR4/4A TR4a cooling questions Triumph 9
sqbsprite TR6 Electric cooling fan switch - where is best location to mount? Triumph 2
mgedit TR2/3/3A Cooling System Flush Triumph 32
Bremer TR2/3/3A Heater removal and engine cooling Triumph 11
NutmegCT Cooling system clean/flush Restoration & Tools 11
D TR4/4A TR4A cooling hoses Triumph 2
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
steveg Cooling system filter installation - xpost Austin Healey 6
richie TR4/4A TR4a Cooling system temperatures Triumph 10
H oil cooler overall cooling component Austin Healey 7
T Cooling fan options Triumph 24
HealeyRick Electric Cooling Fan Install Austin Healey 5
M Electric cooling fan Triumph 2
H Dennis Welch Cooling Fan Austin Healey 9
M TR2/3/3A TR3 metal cooling pipe. Triumph 4
I Cooling a stock Bugeye Spridgets 13
R TR2/3/3A TR 3A Cooling Fan Conversion Triumph 16
mgedit TR2/3/3A 56 TR3 Cooling System Triumph 2
R upgrade to electric cooling fan? Spridgets 17
G Evans Cooling NPG+ Austin Healey 0
T XKE Series 2 Cooling System Jaguar 0
T Cooling: water vs antifreeze vs Water Wetter Austin Healey 16
bigjones 1500 - electric cooling fan Spridgets 6
luke44 Wedge Tr8 Cooling fans Triumph 6
RJS Aftermarket Cooling Fans Triumph 3
Jer plastic cooling fan options for 1275 Spridgets 4
RJS Cooling System Flush Triumph 3
RJS Reversed Cooling Fan Triumph 8
