Guinn
Help! I put new boots on the steering rack. This requires removing the ball joints which was no problem BUT when I was re-installing the driver's side ball joint, the nut went part way on, then the nut and the ball joint shaft started turning together. Can't get the nut ON nor OFF. There must be a trick to this, so can anyone help me?
Thanks, Guinn /ubbthreads/images/graemlins/cryin.gif
