Ball Joint and Tie Rod Grease Zerc Fittings
KVH
Since the new tie rod ends and ball joints for TRs from some suppliers have no grease fittings, is there a theory out there that the new sealed versions should last a lifetime (or are somehow better), or is there a quality issue here?
Moseso
"Sealed for life" ball joints can also be viewed as "sealed for death" ball joints. Most sealed ball joints do give good wear, but I can't imagine that they would out-last ball joints that see fresh grease from time to time.
TR3driver
Great Pumpkin - R.I.P
The question is, whose lifetime? Generally they mean the lifetime of the joint ... :devilgrin:
More seriously, even if they mean the lifetime of the car; these cars were made with an expected lifetime of perhaps 10 years or so. We have already kept them running for many times that long, and I at least hope to flog mine for many more.
TR6BILL
Mine from TRF came with grease fittings. The OE did not have them. I grease all fittings regularly. When I pulled down my rear end, happily I was able to grease the U-joints that are otherwise inaccessible. Even greased my spline. And had a PSA test done the same week. I hate it when he pops that rubber glove......
TR4
That reminds me of the advice my Dad gave me when I had to get my first Prostate exam, "Look for a Dr. with skinny fingers."
K TR2/3/3A Inner tie rod ball joint. Triumph 6
D TR4/4A inner tie rod ball joint tension Triumph 0
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
M Ball joint/tie rod ends Triumph 8
S tie rod end/ ball joint tool Restoration & Tools 10
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
Keith_M steering rack inner ball joint Spridgets 14
D Side Rod Ball & Joint Installation Austin Healey 17
W Etype lower ball joint removal Jaguar 14
J New Ball Joint for Control Arm or use the old one? Triumph 4
T Help on ball joint - vertical link fit Triumph 20
doughairfield Ball joint to spindle Triumph 3
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
Tabcon New Ball Joint Install Help Needed. Triumph 2
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
J Ball joint and steering question Triumph 12
bigjones Upper Ball Joint Fun and Games Triumph 15
S Greasing new upper ball joint? Triumph 5
C Turning ball joint Triumph 6
M TR4/4A TR4A upper Ball Joint Removal Triumph 9
J Spitfire Ball Joint replacement on Spitfire Triumph 1
M XK 140 Lower Ball Joint Jaguar 1
S TR2/3/3A Tr3 ball joint play Triumph 2
C TR2/3/3A TR3 Ball Joint Replacement Triumph 2
Guinn Ball joint problem!!! MG 4
nevets ball joint rubber boots Austin Healey 2
1 E type upper ball joint rebuild... anyone done one Jaguar 1
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
Joe Reed General MG MG logo ball point pens... MG 0
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
T sourcing linkage ball/sockets Austin Healey 13
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
Mark_Barton Ball bearing in Float Chamber? Triumph 8
M Broken Ball Joints Spridgets 14
