The other white BE did have more bling, which was not my intent when I built it. Most all people commented that mine was the most original. It was interesting that 2 of the 4 BEs had the rear bumperettes upside down. I finally got up the nerve to ask them which way was correct, knowing full well that big end is up, as I installed mine. They knew that their way was wrong, but they liked the look! Again, if it didn't look right from the factory, it seems fair game to change it. I am very proud of my outside rear view mirror, in that it gives a reasonable period look, and NO HOLES WERE DRILLED!
Also, the fuse and relay box under the dash is really hidden, unless one knows were to look. The wiring looks original except for the extra wire on the dizzy (Pertronix) and one wire taped off for the horn. I used a control box converted over to electronic, also identical to the original.
Scott in CA
