RAC68
While going through my Healey in preparation for spring drives, I pulled the rear drums to determine if I had any reminisce of a slight hub leak discovered last fall and corrected (I thought) with the installation of new “O” ring seals and paper gaskets. When pulled, a very slight damp area appeared around the lug studs so I am considering the replacement of axel seals but I also had another thought.
When discussing the issues of scuttle shake, it was commented that running with imbalanced rear drums could prematurely ware the axel bearing. Since replacing the seal is planned but determining ware in the bearing, unless very obvious, is beyond my experience or tools, what is the likelihood of having a deteriorated bearing given the following:
I look forward to your opinions,
Ray (64BJ8P1)
- A new axel bearing set was installed in 1989.
- Approximately 40K miles was driven since bearing installation.
- Both drums were quite out of balance.
Ray (64BJ8P1)
