TR2/3/3A Alternator for TR3
jkent59
Thanks for the help on my last posting, the TR4A manifold is in the shop getting ready for it's new life! The other project I need help on is converting from the original generator to an alternator. I've read a couple articles on the wiring aspect and mounting and feel comfortable with it, however, I'm a little up in the air over the pulley that I need to use. Is there a "ready to use" alternator out there that's compatible with with the pulley on the front of the crank? I've checked out a couple of the complete kits avaliable on the net and the seem way over priced! Thanks again for your help!
Simon TR4a
I have been planning to do this on the TR4, though it is off the road right now so no progress.
I purchased a rebuilt Lucas alternator so as to keep as authentic as possible even if not original; I think the wide belt pulley from my generator will fit.
The kits are expensive because they include new pulleys to use a modern, narrow belt, sometimes people adapt a harmonic balancer from an MGB for use on the crankshaft pully.
There are also some Delco and Bosch alternators which fit easily, but the output may be too great for a car without modern electronic conveniences like rear defroster, big stereo, electric fuel pump etc.
Let us know how the project turns out!
Simon.
J
jkent59
Thanks for the input. We're going to replace the wiring harness when the body work is finished and we're upgrading the lights to halogen so the extra output from the alternator will be a big plus. We also have an electric fuel pump which was in use when the car was running, a hot coil for the electronic ignition and a reduced gear starter ( we plan on driving this car a lot!). Any suggestions on the ampes output we should be looking at with an alternator?Thanks for your help....
Simon TR4a
My TR4a has electric fuel pump, Pertronix ignition and electric fan, and was running on the original generator which has about 25 amp output. Problem is driving at night or in rain when you have everything going, at stoplights lamps dim, turn signals slow down, screen demister is useless. (I also use a small battery to save weight!)
Any increase should help; I think the Lucas alternators are 35-43 amp output depending on model.
Simon.
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
TR3driver TR2/3/3A Mea Culpa - TR3 Alternator conversion Triumph 1
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
mgedit TR2/3/3A Alternator Conversion TR3 Triumph 7
RedTR3 TR2/3/3A TR3 Alternator Conversion Triumph 3
H TR2/3/3A TR3- Who offers a good alternator kit + starter Triumph 28
T TR2/3/3A New TR3 alternator Triumph 19
T TR2/3/3A TR3 alternator conversion Triumph 19
H TR2/3/3A TR3 Nippondenso Alternator Triumph 24
B TR2/3/3A TR3 Denso alternator conversion question Triumph 2
martx-5 TR2/3/3A Delco Alternator on TR3 Triumph 7
bluemiata90 TR2/3/3A TR3 alternator conversion problems Triumph 5
gsalt57tr3 TR2/3/3A TR3 Alternator Conversion Triumph 3
D TR2/3/3A TR3 alternator conversion Triumph 1
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
