Adjusting Rear Drum Brakes 64' Sprite
z0sense
Just a quick question.
I am new to British cars. This 1964 MKII Spite is my first:smile:
Just wondering how to a adjust the rear drums. I see the adjusting screw at the bottom of the brake.
If anyone has a technique or some helpful info, let me know.
Cheers
Tullamore
That screw at the bottom is it. If yours is stuck you should purchase a brake adjuster wrench so that you don't end up stripping it. Just tighten it till the brakes just start to engage and then back it off a little bit.
spritenut
Hold on just a sec.
Is your 64 an early or late?
Later 64s went to disc brakes and with the discs the rear brakes changed too. Those adjust via a 5/16 square adjuster behind the back plate.
Early all drum Sprites used a straight screw inside the brake drum. It is accessable via a hole in the stock rim and a rubber plug in the brake drum that should be lined up with the hole in the wheel.
Just use a screw driver on this set up.
Frank
Tullamore
I always wondered why that plug was there, I thought it was to able to check the brakes without taking the drum off.
George Zeck
It's a small screw /adjuster. Easy adjustment. I had toreplace the master cyl -- used Apple Hydraulic. Works well. I also have a 64 -- feel free to send me Q's.
Tx-
George Zeck
1964 Sprite MKII
/ubbthreads/images/graemlins/hammer.gif
Z
z0sense
I have the screw behind the backplate. I have disc up front as well.
I appreciate the offer George I am sure you will be hearing from me /ubbthreads/images/graemlins/smile.gif
john_j
Make sure there's some slack in the handbrake cable before you adjust the brake shoes. If the cable is pulling on the lever that sticks out of the wheel cylinder, you'll never get the shoes adjusted correctly. (Voice of experience, having made this mitake when I rebuilt my car....)
77MidgetMkIV
I have that access plug on the front of my new drums for my '77 midget as well. I also thought it was for access! I have the square nut on the backplate, and disc up front. They must've kept the original part design to use up the surplus and save some $$.
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
C Adjusting rear brake steady posts Austin Healey 3
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
