Bugeye jack points to remove rear axle
drooartz
I've been AWOL for a while, finally gathering myself back together.
I'm ready to dive into my Bugeye restoration, and have my first of very many questions. I want to pull the rear axle and suspension off so that I can rebuild it all on the bench. Where is the best place to jack up the car so that the rear axle will be free? I've got the car on my 4-post lift so I need to use the jack tray and a little ingenuity for this one. I've got some bottle jack/stand combos that should work fine, and I may need to engineer a beam if I need to go any wider.
Thoughts?
JPSmit
I recall that I used a 2x4 across the car and then jackstands under the 2x4
I use the pinch weld under the sills. Maybe use JP's advice but cut some grooves in the 2x4 for the pinch weld.
drooartz
drooartz
Thanks guys, that makes sense. I was thinking that the pinch weld at the back of the rear bulkhead was likely strong enough. A slotted 2x4 would be easy enough to put together.
JPSmit
I don't recall that I slotted it - though it makes sense. However, I might double up the 2x4 below the slot as, depending on the depth, if the jackstands are outboard of the pinch weld (or get bumped) it won't take much to crack the lumber. Belt and braces. :cheers:
SaxMan
On my '69, I was told to put jack stands underneath the mount points for the springs forward of the rear wheels on the body tub. I know the Bugeye uses the 1/4 elliptic springs, so it may be different.
drooartz
drooartz
Thanks, I was looking at those mounts as well
JPSmit
Recall too that this doesn't weigh a lot so it is more about holding it steady than anything else.
drooartz
drooartz
True. My car doesn't currently have any drivetrain (or much of anything else). I've contemplated tying down the front end just to be sure.
JPSmit
Might not be a bad idea and recall that you probably won't be able to torque everything up properly until the engine gives it some weight, otherwise you can move the whole car - don't ask me how I know. :D
drooartz
drooartz
I sense a story. 😁
Planning on tying things down just to be sure, and good thought on torquing things down.
I assumed you were going to remove the springs as well.
But if you are not removing the springs then certainly the spring plates are the best best.
drooartz
drooartz
I am going to remove the springs. Do I need to fully remove the spring plates or just the rearmost bolts?
JPSmit
I think it will depend on the condition of the plates - if no rust, leave them.
BTW this thread started Dec 6, it is now Dec 13. I suspect there is about 3 hours work. Just sayin' :ROFLMAO:
(says the pot calling the kettle black :ROFLMAO: )
drooartz
drooartz
Fair enough JP, but in my defense I have 2 weeks off for winter break, that's when I'll dive in. I did buy a 2x4 to use for jacking the car up, so I have done something. 😁
JPSmit
and clearly your budget for car work this month went into that 2X4 :ROFLMAO:
drooartz
drooartz
Hey, I also bought some stands/jacks. Give me some credit. 🤪
JPSmit
That was more of a comment (slightly belated) on the ongoing price of lumber :D
I would remove the rear springs to clean and remove the rust from both the pocket and the spring itself. The pan itself is welded in place.
M Bugeye engine removal with floor jack Spridgets 14
I Bugeye jack handle Spridgets 4
I Bugeye jack handle Spridgets 12
I Bugeye jack handle Spridgets 9
I Bugeye factory jack bag help Spridgets 1
I Bugeye original jack bag Spridgets 1
jlaird Bugeye jack ratchet Spridgets 0
apbos Another Bugeye for Jack???? Spridgets 2
H WTB - Spare Wheel and Jack for Bugeye Sprite Austin Healey 0
ncbugeye Jack's Interesting Bugeye Mirror Spridgets 20
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
