I remember mine coming with the rubber/metal bushings coming pre-installed but it wouldn't hurt to double check with Moss. I think I've replaced every bit of rubber on that page ... all the Panhard Rod bushings, the rebound buffer and even the conehead looking Axle buffer that was MIA. Much easier to replace all that stuff with the springs off.
Also, a piece of advice. Spray penetrating oil on the pins and nuts and U bolts that hold the springs. Do this each day until the parts arrive! Also, when trying to break the bolts loose, tighten them slightly first, then back them off.
G'luck,
John
