Replacing rear leaf springs
bighly
When replacing the rear leaf springs, is it also recommended to replace other bushings etc?
Henri
This might sound stupid...but while your fixing the leaf-springs why not replace anything that might need to be replaced as a precaution...why do it later...including any of your bushings...check shocks...any and all parts really...if it looks like it will need to be replaced in the next 6-12-18 months...save yourself the time and/or the extra cost...do it now..why wait?
ThomP
I have a philosophy for LBCs: "If it's rubber and you touch it, REPLACE IT!" The extra cost of most rubber bits is much, much less than the agony and effort required to re-do the job later, because one of those 35+ year old rubber parts failed.
I also understand that polyurethane parts are available ot upgrade those old, rear suspension parts.
Steve
Platinum
Couldn't agree more. Whilst everything is apart anyway, why not replace the bushings? Save you having to do the job all over again, and keep in mind that new parts tend to expose the weaknesses of old parts, which then fail sooner than they otherwise would. Also, Murphy's Law is an absolute given with British cars!
John Loftus
I remember mine coming with the rubber/metal bushings coming pre-installed but it wouldn't hurt to double check with Moss. I think I've replaced every bit of rubber on that page ... all the Panhard Rod bushings, the rebound buffer and even the conehead looking Axle buffer that was MIA. Much easier to replace all that stuff with the springs off.
Also, a piece of advice. Spray penetrating oil on the pins and nuts and U bolts that hold the springs. Do this each day until the parts arrive! Also, when trying to break the bolts loose, tighten them slightly first, then back them off.
G'luck,
John
John Loftus
Wanted to point out the rear springs come with new bushings at both ends where they attach. I agree that anytime you are rebuilding something you should look closely for other worn, damaged or loose parts. The only trouble with this approach is job inflation. You know, do a brake job and it turns into a full frame off restoration.
Cheers,
John
bighly
bighly
John,
Moss lists the bushings as a seperate part 680-960. I'll remember not to order them.
Thanks.
Ed Kaler
John Loftus wrote and I quote:
"Also, when trying to break the bolts loose, tighten them slightly first, then back them off."
I should like to add that after giving all fasteners the "...tighten slightly..." move, REspray penatrent.
Also, if you can (VERY, VERY slight pressure on nozzel) "foam" the stuff on, works better!!
Good Luck!!
Ed
bighly
bighly
I just cant help but laughing and thinking my whole project would have gone smoother if I just dipped the whole car in penetrating oil before starting.
I'll get more penetrating oil.
Johnny
My two cents worth. Most likely, you'll have to replace the 'U" bolts that hold the springs to the rear axle.
Johnny, 59bn7
D Replacing rear leaf springs ? Triumph 6
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
R TR2/3/3A Replacing rear springs Triumph 51
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
GTP1960 TR2/3/3A replacing rear axle buffer? Triumph 6
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
K TR2/3/3A Replacing rear seal on gearbox? Triumph 10
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
M Tips for replacing Rear Sway Bar Bushings? MG 0
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
vping Need Tips on Replacing Rear Suspension Bushings MG 7
jimbar Replacing rear valance panel Triumph 3
MGretired Replacing rear bearings MG 5
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
