General Tech Electrical question
Simmo
Does anybody know a good reason why the positive side of the ignition coil is not fused.
In all the circuits I have seen the feed for the coil comes directly from the ignition switch and bypasses the fuse box.
That doesn't seem to be ideal to me.
Sarastro
Yes, I've always suspected that to be the reason. The fuses common in those days were not terribly reliable, and often "blew" for no obvious reason. That's a safety matter. I suspect that the headlights are unfused for the same reason. The unfused headlights and ignition are not uncommon in other cars of that era.
ed_h
On fusing headlights, it's a matter of design philosophy, and there seems to be two camps on this question. Even the range of aftermarket fuse/relay modules is split on this issue.
One option: Feed the high and low beam circuits from different fuses.
Ed
SherpaPilot TR6 Electrical Question Triumph 7
JimTR4 TR4/4A Electrical question Triumph 5
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
B Electrical Question Spridgets 8
longbridgehealey Bugeye electrical question Spridgets 9
nevets Troubleshooting OD electrical question Austin Healey 6
nevets Overdrive electrical diagnostics question Austin Healey 5
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
E another dumb electrical question Austin Healey 8
Jim_Newman dumb little electrical question Austin Healey 3
glemon Turn Signal Electrical Question Triumph 11
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
JPSmit New Beetle electrical question Restoration & Tools 9
Mental Old lurker with an old electrical question... MG 10
bighealeysource Driving lights electrical question Austin Healey 3
G Electrical Question and Possible Dilemma Triumph 24
Steve P. Bugeye electrical layout question Spridgets 7
D Electrical Question for a friend.... Spridgets 14
JPSmit electrical question of sorts Spridgets 6
JPSmit progress - and electrical question Spridgets 5
JPSmit dash lightbulb and flasher [electrical] question Spridgets 3
Tim Tucker TR6 TR6 Electrical Question/Suggestions Triumph 11
T Overdrive question - electrical Triumph 14
H Electrical conversion question Austin Healey 1
Luke_Healey Noob with a big electrical question Spridgets 22
D TR4/4A TR4-A Electrical Question [Again] Triumph 8
jlaird Question electrical Spridgets 2
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
S TR2/3/3A tr3 electrical question Triumph 9
kyreb1862 Another Electrical Question MG 8
kyreb1862 MGB MGB Electrical Question MG 15
77_MG_Midget 77 midget electrical question Spridgets 6
TR4 Electrical Question Triumph 4
77MidgetMkIV question on electrical gauge wiring Spridgets 14
curtis Electrical question Austin Healey 7
EMGEBE Electrical Question. MG 3
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
