General Tech Electrical question
Simmo
Does anybody know a good reason why the positive side of the ignition coil is not fused.
In all the circuits I have seen the feed for the coil comes directly from the ignition switch and bypasses the fuse box.
That doesn't seem to be ideal to me.
Yes, I've always suspected that to be the reason. The fuses common in those days were not terribly reliable, and often "blew" for no obvious reason. That's a safety matter. I suspect that the headlights are unfused for the same reason. The unfused headlights and ignition are not uncommon in other cars of that era.
On fusing headlights, it's a matter of design philosophy, and there seems to be two camps on this question. Even the range of aftermarket fuse/relay modules is split on this issue.
One option: Feed the high and low beam circuits from different fuses.
Ed
