Question electrical
jlaird
Was just messing around.
Have juice at the coil from the hot lead when I ground the other end of my tester to the car but not across the low voltage terminals.
Am I correct in that the points are open??
GB1
most likely,
try pushing Agatha a lil bit in gand check again.
Patrick
jlaird
jlaird
Sure wish I had a choke cable, had to send the one I got back. Now waiting for a real one. sigh.
Simmo General Tech Electrical question Triumph 4
SherpaPilot TR6 Electrical Question Triumph 7
JimTR4 TR4/4A Electrical question Triumph 5
RJS TR4/4A Electrical Question - brake lights, fuel/gas gauges, turn signals failed Triumph 9
B Electrical Question Spridgets 8
longbridgehealey Bugeye electrical question Spridgets 9
nevets Troubleshooting OD electrical question Austin Healey 6
nevets Overdrive electrical diagnostics question Austin Healey 5
Jim_Newman Another little electrical question - fuel gauge. Austin Healey 3
E another dumb electrical question Austin Healey 8
Jim_Newman dumb little electrical question Austin Healey 3
glemon Turn Signal Electrical Question Triumph 11
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
JPSmit New Beetle electrical question Restoration & Tools 9
Mental Old lurker with an old electrical question... MG 10
bighealeysource Driving lights electrical question Austin Healey 3
G Electrical Question and Possible Dilemma Triumph 24
Steve P. Bugeye electrical layout question Spridgets 7
D Electrical Question for a friend.... Spridgets 14
JPSmit electrical question of sorts Spridgets 6
JPSmit progress - and electrical question Spridgets 5
JPSmit dash lightbulb and flasher [electrical] question Spridgets 3
Tim Tucker TR6 TR6 Electrical Question/Suggestions Triumph 11
T Overdrive question - electrical Triumph 14
H Electrical conversion question Austin Healey 1
Luke_Healey Noob with a big electrical question Spridgets 22
D TR4/4A TR4-A Electrical Question [Again] Triumph 8
prb51 TR2/3/3A TR3 simple electrical question Triumph 5
S TR2/3/3A tr3 electrical question Triumph 9
kyreb1862 Another Electrical Question MG 8
kyreb1862 MGB MGB Electrical Question MG 15
77_MG_Midget 77 midget electrical question Spridgets 6
TR4 Electrical Question Triumph 4
77MidgetMkIV question on electrical gauge wiring Spridgets 14
curtis Electrical question Austin Healey 7
EMGEBE Electrical Question. MG 3
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
