TR2/3/3A Dot 5
Redoakboo
I am in the late stage of restoring a 54TR-2 Long Door. The brake system is all new, master cylinder, wheel cylinders, clutch slave cylinder. The steel lines were good, flushed good before re-installing. I have heard the pro's and con's of using DOT 5. Any suggestions, guys?
2long
Should go with DOT5. With all new braking system, one of the "cons" is eliminated as there is little to no chance of mixing fluids. DOT5 does better for vehicles stored for periods of time, and of course won't melt paint. I have had it in my Doretti and TR2 for years and no problems, both have firm pedals. Let the debate begin!
Dan
Jim_Stevens
After I saw the mess that occurred over the years in the paint beneath the reservoir, I went with DOT 5!
Before:
and after:
bobhustead
I've been using DOT5 in my TR3 for 5 or 6 years. I have seen no "cons". The main "con" of DOT3 is that a paint sprayer is hard to get into the engine box when the fluid damages your paint, which it surely eventually will.
ed_h
I've watched these online DOT3-4/5 debates for years. Opinions usually seem to favor DOT5 by a ratio of 4 or 5 to 1 and increasing.
I use DOT5 and see no good reason to switch back.
Ed
R
Redoakboo
Thanks Guys, DOT it is!
Dick
TR3driver
Great Pumpkin - R.I.P
FWIW, you can partially compensate for the soft pedal by converting to the braided stainless brake hoses. They swell less under pressure than the originals.
I've lost track of just how long I've been using DOT 5, got to be around 35 years. I really like it and recommend it; unless you want to be absolutely original and have brake problems every year. That's one part of the "Triumph experience" that I'm glad to miss out on!
glemon
I have posted this before, I have used DOT 5 for years, and have fewer leaks in the hydraulics, which used to be a more regular occurrence. No problem with mushy pedal or blessing. However after about 8 years I had a brake master cylinder fail. It wasn't the rubber, when I took it apart there was a line of corrosion straight down the bottoms of the bore.
DOT5 doesn't absorb water, it sinks to the bottom of the mix. My fault for not flushing often enough, and I still use it, but in my mind that is the real issue with DOT5.
AUSMHLY Castrol DOT 4 vs Other Brands Austin Healey 6
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Rhodyspit75 DOT 5 and DOT 5.1 Spridgets 1
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
M TR2/3/3A Intermix of Silicone and Dot 3 brake fluid Triumph 7
S TR2/3/3A Question on the lift dot fastener, Triumph 3
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
T TR2/3/3A Lift the Dot question Triumph 4
TulsaFred Timing Gears dot to dot Spridgets 9
C TR6 TR6 with dot 5 brake fluid Triumph 8
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
vette Silicone DOT-5 Brake & Clutch Fluid Austin Healey 17
NutmegCT brakes: DOT 3 or DOT 4? Restoration & Tools 2
C TR6 Dot 5 in a TR6 rebuild Triumph 17
Q TR2/3/3A Using DOT 5 Brake Fluid On TR3A Triumph 34
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
S dot 5 brake switch Triumph 14
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
C Converting to DOT 5 Triumph 6
Steve_S The New M.G. Nuts dot com MG 1
CJD DOT 5 Brake Fluid Triumph 38
M Removing Lift-the-Dot Fasteners Triumph 8
tahoe healey DOT 5 going away? Austin Healey 8
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bighealeysource Push the Dot post on dash of BN6/BN7 Austin Healey 1
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
C "Lift-a-dot" studs Austin Healey 9
ekamm lift-a-dot studs Triumph 8
Jim_Gruber Brake Fluid - Castrol LMA Dot 3 or Dot 4? Spridgets 2
Brosky Stag Trimph TransAmerican Stag pics added to DOT Triumph 24
dklawson New Brake MC & Warranty with DOT-5 Fluid? Triumph 41
davidk Flushing DOT 5 Fluid Triumph 5
H TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR Triumph 4
dklawson A-Series Dot-to-Dot Cam Setting [TDC?] Spridgets 3
J dot 4 brake fluid Other Cars 4
M Dot brake fluid, question Spridgets 10
S DOT 3 or DOT4 Brake Fliud Triumph 44
Brooklands Lift the dot fasteners Restoration & Tools 8
Brosky Silicone vs Dot 4/5 in new CLUTCH hydraulics? Triumph 17
Harry_Ward Lift the dot stud type for tonneau cover? Triumph 13
Trevor Jessie 4 year old dot dissappointed with steering wheel Spridgets 4
G Dot Snaps Triumph 2
C DOT 4 vs DOT 5 Triumph 14
