TR2/3/3A Problem with lift-the-dot fastener on door
jfarris
The forward-most lift-the-dot fastener on my passenger door has come out. It is the kind with a long screw shank. I assumed it had been screwed into the block of wood that locates the side screens, but there is no wood directly behind it. So, I purchased a fastener with a bolt shank and nut to install. Surprise when I took the panel and then the topper off the door, that piece of wood is three pieces that form the top of the door and the outer door skin appears to be nailed to it. There is no way I am going to try to remove that to get to the back of my fastener hole. So, what is a reasonable fix - stuff JB Weld, Gorilla Glue, liquid nails, etc in the hole and reinsert the fastener or _____?
Thanks in advance,
TR3driver
Great Pumpkin - R.I.P
Are you sure there isn't wood around the hole, that is just stripped out from where the stud pulled out? I just took a look at my 56 and I'm pretty sure that front stud is screwed into wood.
If so, then what I do is get a wooden kitchen match, coat the end with a bit of wood glue (Elmer's will do if you don't have anything better on hand) and jam that into the hole as far as it will go. Break it off flush, and repeat if there is room for another one (ISTR those studs were small enough for one matchstick). Screw the stud partway in, then wait for the glue to dry before seating it all the way.
Got_All_4
I certainly would try Randals idea first. if it doesn't work or your set on using the machine threaded stud you purchased then take a drill bit just smaller then the hole and drill all the way through even through the back frame of the door. Next get a drill bit a little bigger then the hex nut and drill from the back side towards the door skin. Make sure you measure the depth you need so there is enough of the stud sticking through to get the nut started. So basically your counter boring from the back side. Be carful not to go too deep as not to pop an outie on the door skin.
charleyf
Jim,
my recollection of what the wood piece looked like was that where each of the fasteners had been screwed into the wood there was more of a crater than a hole. I believe the JB WELD idea is a good one to use if Randall's idea does not work. I made a set of the wood inserts for the doors and would not wish to do it again.
Charley
jfarris
jfarris
Thanks to all who chimed in, I used the wood glue and match stick solution. It worked great, I tested it with a 90 mile round trip to the Indy Car race in Birmingham today. Tonneau didn't move, wish the heater worked a little better at 55* this morning.
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
KVH General TR Transmission Problem Triumph 3
DrEntropy W123 Benz recurring problem Other Cars 16
J MGB Idle problem MG 4
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
E MGB MGB heater motor problem MG 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T TR2/3/3A Help - Cooling system problem Triumph 7
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
T General TR Cluthch problem / challenge Triumph 4
M Europa turn signal problem Lotus 7
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
S Engine or Tachometer Odd Problem Austin Healey 7
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
G windscreen problem Spridgets 1
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 New harness installed but have a purple problem Triumph 12
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
C TR2/3/3A TR3 Gearbox Problem Triumph 10
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
R TR2/3/3A Grounding problem Triumph 21
P TR6 Wiring problem Triumph 50
P TR6 Clutch problem not solved Triumph 6
D Acceleration Problem Austin Healey 4
M XK120 fuse problem? Jaguar 5
P 2002 Accord problem Other Cars 31
P TR6 Electrical Problem Triumph 26
