Steering Idler Noise
Martinld123
Bronze
When I shake the right side wheel the steering Idler makes a metal to metal sound and moves up very slightly. Any ideas? New one is $395 I believe. Will check oil later today. Thanks Marty
Healey Nut
So replace the bushings in it , put a grease NIPPLE on it , grease it and say goodbye to it ever having issues again .
vette
Yep, do that. This is what it looks like. Be sure to shim the zerk fitting with a thin washer because its threads will go too deep and groove the shaft if ya don't. If your idler arm and shaft are moving up and down your bushings are shot. You will drive the new bushings in place then hone them some until the shaft fits snug but not too tight to turn.
Martinld123
Martinld123
Bronze
Marv thanks for offer but so far with help from people on here I may have solved problem. I took cap off and backed off filler plug so it could not hit shaft and also filled it with grease. Sounds good so far. Thanks Marty
Martinld123
Martinld123
Bronze
Zerk fitting seems to be the way to go in future but after taking top off, backing off plug, and filling with grease sound seems to be gone. I would like to maybe put bushings in someday but the honing word scares me. It that tool something I can rent at auto parts store? Will look up on Internet to see. Thanks Marty
AUSMHLY
Moss sells a lubricant for the steering box and ldler by Dynolite.
According to Moss' description, regular grease is NOT recommended...for the steering box. No mention of the Idler, so not sure if it encompasses that.
Here's what's written on page A45 in the Moss catalog:
"Our steering box lube by Dynolite is a semi-fluid grease acts as a liquid where greases do not. If you use grease in a steering box the centrifugal action of the internal components flings the grease away, causing it to stick to the casing where it cannot lubricate the components. Semi-fluid grease is able to drain down and pool in the casing enabling continued lubrication".
steveg
Don't believe the idler is the same kind of situation as the steering, where you've got centrifugal forces.
If one is going to use a zerk, consider pumping in Corn Head grease - that way you'd get some flowing.
Steve,
I 'mis-wrote;' I was thinking reamer (most auto machinists will have a set). I wouldn't use a hone for this, if it worked for you, good.
Edit: Did you hone your king pin bushes the last time you replaced them?
steveg
Steve,
Bob,
When I bought my BJ8 spindles, the kingpin bushes were already honed to size. I only replaced and honed my steering box bushes. My idler has been good except for adjusting the vertical play by removing a shim or two.
Hmmmmm ... anybody know if there's any brass or bronze in a Healey rear-end? I see some thrust washers on the diagram, and they are usually bronze; may have to get the 75W-140 out of there (though I've put probably 15K miles on it with no issues).
Edit: Just checked with David Nock and he says the thrust washers are indeed bronze/brass--bronze, probably--but he said he's 'used GL-5 for years' and never seen a problem with it. What to do, what to do ...
AUSMHLY
Bob, this should probably be on the rear end thread, where I'm talking about this right now. Would you ask it there and let me know what oil you plan on using. Handbook says GL-4, 90w
Honing is appropriate for breaking glaze on cylinder walls and cleaning up minor pitting on brake cylinders, but king pin bushings should be reamed. The bushes themselves need to be carefully installed so that the greasing passage aligns with the channel on the bushes, and the bushes need to be exactly aligned with each other. You need a reamer to do this:
https://mossmotors.com/reamer-swivel-pin-bushes
If you can't find someone local to do it, BCS can do it.
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
T TR2/3/3A Question on steering idler unit Triumph 2
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Lutz Kramer Steering box and idler bush Austin Healey 4
G Steering idler arm removal Austin Healey 33
RickPA Need help installing steering idler oil seal Austin Healey 6
RickPA Clunky steering idler Austin Healey 8
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
S Austin Healey New Steering Idler Assembly Austin Healey 2
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
6 Problem after installing new steering idler Austin Healey 15
6 Problem Removing Steering Idler BJ8 Austin Healey 9
6 How do you remove steering idler on BJ8? Austin Healey 0
6 Idler steering Assembly Problem [BJ8] Austin Healey 7
F Steering Idler Austin Healey 14
M Steering idler bushing direction Austin Healey 3
C Steering Idler problem Austin Healey 7
A How do I convince steering arm to come off idler? Austin Healey 10
N Steering Idler Box Austin Healey 3
nevets steering box and idler removal Austin Healey 14
C steering idler Austin Healey 5
S BJ8 Steering Idler Assembly Austin Healey 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
