On the steering idler unit (under the section: TO FIT IDLER UNIT) the manual says to screw the fulcrum pin into the housing and unscrewing one full turn; ensure also that the grease seal is in good condition. Am I correct to assume that the pin is screwed in with the seal over the pin and thus the pin is screwed down against the seal? On mine when I unscrew the pin one full turn from being down against the seal, I end up with a 1/16 inch gap between the seal and the "top" of the pin. The seal is right at 1/8 inch thick so when I unscrew the pin, the total gap ends up 3/16 inch. Is my seal flattened down and thus not expanding up against the top of the pin...my seal is not new? How thick should the seal be? Thanks!
Bob
Bob
