Martinld123
When I shake the right side wheel the steering Idler makes a metal to metal sound and moves up very slightly. Any ideas? New one is $395 I believe. Will check oil later today. Thanks Marty
Yep, do that. This is what it looks like. Be sure to shim the zerk fitting with a thin washer because its threads will go too deep and groove the shaft if ya don't. If your idler arm and shaft are moving up and down your bushings are shot. You will drive the new bushings in place then hone them some until the shaft fits snug but not too tight to turn.So replace the bushings in it , put a grease NIPPLE on it , grease it and say goodbye to it ever having issues again .
Steve,
I 'mis-wrote;' I was thinking reamer (most auto machinists will have a set). I wouldn't use a hone for this, if it worked for you, good.
Edit: Did you hone your king pin bushes the last time you replaced them?
Hmmmmm ... anybody know if there's any brass or bronze in a Healey rear-end? I see some thrust washers on the diagram, and they are usually bronze; may have to get the 75W-140 out of there (though I've put probably 15K miles on it with no issues).
Edit: Just checked with David Nock and he says the thrust washers are indeed bronze/brass--bronze, probably--but he said he's 'used GL-5 for years' and never seen a problem with it. What to do, what to do ...
