AngusSaunders
Seems I hit a snag. The lower passenger side door hinge was working stiff and somewhat odd. Well the pin was sheered and quite frozen to all the aluminum parts, not sure what was holding it together. I have soaked it in penetrant and tried to use heat to remove the pin parts but no luck so far. Has anyone had any luck repairing these hinges? There is a guy on ebay that refurbishs these hinges, has anyone used his services? A couple of more questions if I may. Are the passenger side and drive side hinges the same. Are all of the 3000 hinges the same. Thanks for listening to my tale of woe.
