TR2/3/3A TR3 Door hinge removal fun!
Beerzz
Member
Like most screws and bolts on the car, no easy solution. I need to get them off. Soaked them...bla bla bla Thanks for any suggestions. Ben
prb51
are both sides stuck fast. You may be able to access the rear of the bolts thru the forward side kick panels...on the right there is usually a cutout behind the carpet for a speaker...more lubricant.
On the early cars the original hinges were brass, try heat on the bolts. I've had luck using a punch that fits the screw pattern and a mallet.
M_Pied_Lourd
Ben,
Had the same experience as you. After a week of penetrating oil front and rear on the cage nuts( I had the front wings off), they still wouldn't budge (like the seat tracks).
I should mention that I was able to remove the doors as I could get the fasteners off the door hinge side. I left the hinges on the car until I could get them off....
I used heat and an impact driver/bfh to get them off.
Cheers,
M. Pied Lourd
TR4nut
For some reason, it seems that the door side is easier - I agree that impact driver works well here.
tdskip
Ben - I'm thinking you've been through this drill before. Nothing special about TRs in this regard, unfortunately, to pass along. Hang in there.
PeterK
I've got a big screw driver with a square stem that fits a 5/16" wrench. It adds a lot more torque than twisting.
But the hand impact screwdrivers work well for door hinges. I always hit them once in forward, then reverse and hit with bfh.
Kleykamp TR2/3/3A TR3 Door hinge hole pattern??? Triumph 12
M TR2/3/3A TR3 door hinge repair ??? Triumph 3
G TR2/3/3A TR3 Door Hinge Problem Triumph 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
S TR2/3/3A wood next to the door on a tr3 Triumph 4
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
J TR2/3/3A door gaps on a TR3 prior to paint Triumph 13
Kleykamp TR2/3/3A TR3 cowl vent door spring Triumph 3
Kleykamp TR2/3/3A Interior door pulls on TR3?? Triumph 5
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
T TR2/3/3A TR3 Door seals Triumph 6
B Door Capping on a TR3 Restoration & Tools 0
mgedit TR2/3/3A 56 TR3 Door Question Triumph 8
PatGalvin TR2/3/3A TR3 Door Rebuild Weatherstripping Question Triumph 10
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
CJD TR2/3/3A TR3 Door Scuff Panels Triumph 4
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
S TR2/3/3A TR3 Exterior Door handles Triumph 4
CJD TR2/3/3A TR3 Rear Door Seal? Triumph 2
B TR2/3/3A Door / rocker panel relationship TR3 Triumph 11
T TR2/3/3A TR3 door gap Triumph 12
S TR2/3/3A door check straps for tr3 Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
T TR2/3/3A TR3 inside door linkage Triumph 8
T TR2/3/3A TR3 door sills Triumph 2
S TR2/3/3A tr3 door too tight Triumph 1
mountainman TR2/3/3A TR3 Door Seals Triumph 8
F TR2/3/3A recovering the door and dogleg cappings on the tr3 Triumph 4
luke44 TR2/3/3A TR3 Inner Door Handle Parts Triumph 16
ekamm TR2/3/3A TR3 door cap button Triumph 4
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
mountainman TR2/3/3A Tr3 Door Cap Triumph 7
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
S TR2/3/3A top door trim tr3 Triumph 4
CraigLandrum TR2/3/3A TR3 door fitting tips? Triumph 16
S TR2/3/3A tr3 door Triumph 4
martx-5 TR2/3/3A TR3 Furflex - Fuzzy Door Seals Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
CCURTISS TR2/3/3A New TR3 Leather Door Pull Straps Located Triumph 4
S TR2/3/3A door strap checking tr3 Triumph 8
gsalt57tr3 TR2/3/3A TR3 Door Cord Question Triumph 3
Earl TR2/3/3A TR3 Door Parts Triumph 6
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
