MGB Crack of doom - Door hinge question
Boggsy64
My 77 B has the "crack of doom" on the passenger door (right by the side window frame attachment point). The door is also a little high, in the rear, so it does not close well. I can press down on the rear of the door and see the top door gap, between the door and the front fender, open and the top hinge flex. It appears the same on both sides but only one side is cracked. I know how to remove the hinge (remove the splash guard in the wheel well, the securing bolt from behind, and then the screws). Question is before I do that, is there a bushing or "wear" element in the hinge that goes bad, or do the hinges just normally flex somewhat? My guess is that I can loosen the hinge screws and get some movement out of the whole assembly to help alignment. I am going to weld the crack and don't want it coming back.
The six screws on the door side of the hinges should give you enough adjustment to align the thing. Shouldn't need to undo the chassis side of the hinge for what you've described.
Mickey Richaud
Platinum
Also, be sure the point where the vent window frame meets the windshield post is proper. Easy to tell from sighting down the side of the car; you'll know if it it's wrong, and if so, it puts quite a bit of stress which can add to the problem.
PAUL161
I've repaired the cracks by the door mirrors, which is very common, by making a plate out of 0.60 material contoured to fit inside the door and welding in place. Re drill any affected holes and the repair will last longer than the original door. PJ
2 TR2/3/3A Headache: Magnaflux found a crack Triumph 5
Csarneson Engine Rebuild Disaster - Cylinder Crack Austin Healey 20
C TR2/3/3A Floor Pan Crack Triumph 5
TRMark TR4/4A Crack in floor at sill mounts Triumph 5
D AH 3000 Front hood crack Austin Healey 2
CJD General TR Block Crack Repair Triumph 41
S TR6 Starter finally cranks...then CRACK. Vicky Brit parts order time. Triumph 5
T TR2/3/3A Hazard::TR3 bonnet stayrod assembly crack Triumph 1
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
bighealeysource surface crack in water outlet elbow on BN2 Austin Healey 3
AEW TR2/3/3A TR3a block with crack Triumph 5
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
Tr4dude TR4/4A anybody want 1st crack on tr4 bitsbefore fleabay Triumph 2
regularman If a 1275 head had a crack in it. Spridgets 25
B Fixing crack in rubber bumper MG 1
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
M Crack in exhaust header... Spridgets 14
A TR2/3/3A TR3/4 head crack, can it be welded Triumph 11
PeterK TR4/4A TR4A exhaust manifold crack story Triumph 28
A TR4/4A TR3 / TR4 head crack repair Triumph 3
S Dash crack Restoration & Tools 8
RickB VERY LITTLE CRACK IN DASH - what to do? Spridgets 9
Geo Hahn Leatherique Crack Filler Restoration & Tools 2
AUSMHLY It's just a little crack Austin Healey 16
jerrybny Differential bracket crack Triumph 5
H Crack in door, is it useable? MG 9
jaybird Somebody's smoking crack MG 11
drooartz MGB MGB door skins and the infamous crack MG 10
T Small crack in rear hubs Jaguar 4
1 Fuel pump needing a tap -- approaching doom? MG 4
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
J TR2/3/3A Looking for helpful hints for door hinge screw removal Triumph 17
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
G Wanted - Glove Box Door for a TR3A Triumph Classifieds 2
T Heater Door Spring Austin Healey 1
C Door Latch Mechanism Austin Healey 3
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 19
B Which is the correct door knob for a 59 bugeye? Spridgets 3
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T Original Door Pocket Spridgets 14
T Interior Door Panel and Top Rail Austin Healey 3
JFS Wedge Door wing window finisher Triumph 2
