What to do about my wire wheels
ChrisR
Hi folks - I've been a member here for ten years but haven't actually posted anything so hope I'm not breaking a rule somewhere.
I have an Austin Healey Sprite that I've been driving around for ten years and have decided to embark on moving it from "barely drivable" status to something a bit more acceptable. One rather obvious aspect of this is the wheels. They are wire wheels that were painted white some time in the past, presumably to hide the gruesome amounts of rust that had accrued.
Does anyone have any idea of what my best approach is to making these shiny again? I have a funny feeling the answer is going to be "throw them away and buy some new ones" but I'd rather be told that now than a few weeks down the line when my kitchen table is covered in lovingly paint-stripped but entirely un-savable spokes. :smile:
Chris
NutmegCT
Hi Chris - first thing I'd do is decide if the wheels are actually worth saving. Bent, out of round, cracked, wobbling, etc. If you just drive around the block, might not matter. But road driving - you want the wheels in good condition - and some wheel issues can't be fixed.
Tom M.
TR3driver
Great Pumpkin - R.I.P
Pay particular attention to the splines; worn-out splines are a safety hazard even just driving around the block.
Unfortunately, they are also the most prone to being attacked by rust, if they haven't been greased on a regular basis.
John Turney
...Does anyone have any idea of what my best approach is to making these shiny again? I have a funny feeling the answer is going to be "throw them away and buy some new ones" but I'd rather be told that now than a few weeks down the line when my kitchen table is covered in lovingly paint-stripped but entirely un-savable spokes. :smile:
Chris
First, congratulations on finally braving to make that first post. We don't bite, at least not hard. :wink-new:
Second, it sounds like you are thinking of disassembling the wheels. I wouldn't do that. Assembling wire wheels and making them run true is not for the faint-of-heart.
Third, as Randall said, the main thing is if the splines and hubs are worn too much, it's a safety problem. The top of each spline in the wheel hub and in the axle hub should be rounded. If the top of each spline is sharp or bent over, the wheel and axle hubs will have to be replaced.
From Classic Motorsports: https://classicmotorsports.com/articles/wire-wheels-classic-cars/
Now comes the most important inspection, the splines. Remove the wheel from the car and clean away the grease from the splines to allow a good visual inspection. The splines should be slightly rounded at their peaks, not sharp. They should also be symmetrical.
The inner 1/4 inch of the splines does not contact the hub, so you can compare that portion to the rest of the spline surface during your inspection. Clean the hubs and inspect them the same way you inspect the wheel. Remember that worn splines are dangerous, so this is an important inspection.
If the splines on either the wheel or axle hub are worn, the only solution is replacement. Further, if you put a new wheel on a worn hub, or vice versa, the new component will quickly wear out. So the best and safest recourse to worn splines is new wheels and hubs.
Ask away!
HealeyRick
Sprite wheels don't seem to be as susceptible to damage as the 15 inch wheels on big Healeys, because of the shorter spokes I think. At any rate, I'd check the splines as mentioned above and check them for trueness by fixing a pointer against the rim and see if it stays in line when spinning the wheel. If everything works out ok, strip the paint, prime and paint them with some Moss wire wheel paint which is a great match to the original color.
C
ChrisR
This is great advice, thank you. I'll check the splines - my guess is that this might send me down the "new wheels and axles" route because there's an ominous clunk from the right rear occasionally when starting off, and now I think about it splines might be the cause of that...
Chris
PAUL161
Remember, when there's a clunk it indicates wear in the splines, but when this happens, it's not just the wheels, it's also the hubs. They wear about the same rate. putting new wheels on worn hub splines isn't a good idea. Just sayin, PJ
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
P TR5/TR250 Wire wheels width Triumph 8
D Wire Wheels and Air Leak Austin Healey 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
Rut TR4/4A MWS wire wheels Triumph 9
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
tahoe healey Wire Wheels Austin Healey 22
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
aero3113 Wire Wheels and Top installed Austin Healey 17
HighAltitudeTR3 TR2/3/3A Balancing Wire Wheels... Triumph 4
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
B wire wheels and broken spokes Austin Healey 19
trglory TR2/3/3A Wire Wheels Triumph 15
AUSMHLY Dayton vs. Dunlop wire wheels Austin Healey 11
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
B wire wheels tire breakdown Austin Healey 23
S TR4/4A wire wheels Triumph 4
trotti Chrome Wire Wheels Austin Healey 5
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
B TR2/3/3A Wire wheels on TR3 Triumph 8
2 TR2/3/3A Dayton Wire Wheels Triumph 4
BN6_2197 185/80 tires on 15'' wire wheels in Germany Austin Healey 10
S TR2/3/3A cleaning wire wheels Triumph 6
Marvin Gruber TR5/TR250 TR250 wire wheels, 60 or 72 spoke? Triumph 6
PAUL161 T-Series New Wire Wheels Mounting MG 11
PAUL161 General MG Chroming Wire Wheels MG 9
maxwedge5281 wire wheels to steel wheels...bn6 Austin Healey 0
drooartz MGB-GT Fighting wire wheels MG 19
T TR2/3/3A TR3A Wire Wheels Basic Questions Triumph 23
RJS TR4/4A Questions: new tires on old wire wheels Triumph 10
S TR2/3/3A Wire Wheels Sealing Triumph 17
P Restore original wire wheels or buy new? Austin Healey 7
K BMC paint colour code AL1 [wire wheels] Austin Healey 1
wangdango Competition wire wheels? Austin Healey 6
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
MikeAH100M Sprite Rear Axle with Wire Wheels Spridgets 11
DerekJ Ever seen wire wheels like this before? Austin Healey 5
Zimmycobra Hendrix Wire Wheels Triumph 5
B Wire wheels? FORUM Navigation Questions 3
Zimmycobra Powder Coating wire wheels? Triumph 10
