Brake hoses
Michael Oritt
In my relatively unsuccessful quest for a consistently hard brake pedal I've decided to replace several components that do not owe me anything--namely the brake hoses and the rear wheel cylinders which have been on the car for at least ten years.
MOSS sells several different brake hoses--stainless steel by Goodridge, braided stainless steel by Cobalt, and unbranded "stock" ones. As between the two metal hoses does anyone have a recommendation for one or the other based on their experience, either negative or positive? I have BT7 front discs and stock rear drums.
AUSMHLY
olphartz provides a photo that show how their stainless are made. Maybe helpful in comparing with other brands.
https://www.olphartz.com/stainless-brakelines.html
John Turney
I have the Goodridge, no complaints. I originally got the Denis Welch hoses when I did the disc brake conversion in 2000. They were fine until one kinked earlier this year.
Michael Oritt
Michael Oritt
I have BT7 front discs and stock late BN1 rear drums. I just spoke with Moss and asked if they can mix and match but they said no, they come in prepackaged kits. I acnnot be sure but since Moss specifies different part numbers for BN1 versus BT7 rear hoses I doubt that ordering a BT7 will work for me.
I cannot find a listing for Cobalt and it looks like they supply a lot of vendors so I doubt I will be able to have them make up a custom set of hoses. Same thing with Goodridge.
I would like to buy a set of SS hoses from either one of these suppliers or someone else but do not feel like buying two kits to harvest the parts I need for one car. Does anyone have any suggestions as to a source?
AUSMHLY
I believe these guys will make for you or sell you what ever you need.
steveg
roscoe
Making hydraulic hoses for any hydraulic shop is often just a function of whether or not they have or can source the fittings and swaging dies. Find a shop, bring a hose by for them to look at and perhaps they can make some for you. It might not be a big deal.
Deleted member 21878
Check with a local farmer. i know a friend of mine over here gets hoses made all the time for his equipment. And it is cheaper.
Michael Oritt
Michael Oritt
After checking out the link to Oldphartz Parts that Ausmhly inserted in his post #6 I made contact with them and received an immediate reply from Steve Christianson who said that making up such a kit is no problem for them. He is on PST time so I have a call into him to finalize the order.
I'll give feedback after I receive and install the parts but whether he is making the hoses or buying them from a supplier it is nice dealing with a seller who has flexibility.
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
F What SS brake hoses do you recommend? Austin Healey 5
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
T TR2/3/3A replacement brake hoses Triumph 2
drooartz General Tech Check those brake hoses! MG 11
RJS TR4/4A Replacing front brake hoses Triumph 10
drooartz Any tips for replacing brake hoses MG 16
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
T Stainless steel brake hoses - two questions Spridgets 13
Atrus Brake Hoses - stainless vs rubber Spridgets 4
floyd TR6 brake hoses 75 tr6 Triumph 5
kindofblue TR5/TR250 Rear brake hoses replacement on TR250 [IRS] Triumph 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
