Brake hoses
Michael Oritt
In my relatively unsuccessful quest for a consistently hard brake pedal I've decided to replace several components that do not owe me anything--namely the brake hoses and the rear wheel cylinders which have been on the car for at least ten years.
MOSS sells several different brake hoses--stainless steel by Goodridge, braided stainless steel by Cobalt, and unbranded "stock" ones. As between the two metal hoses does anyone have a recommendation for one or the other based on their experience, either negative or positive? I have BT7 front discs and stock rear drums.
olphartz provides a photo that show how their stainless are made. Maybe helpful in comparing with other brands.
https://www.olphartz.com/stainless-brakelines.html
I have the Goodridge, no complaints. I originally got the Denis Welch hoses when I did the disc brake conversion in 2000. They were fine until one kinked earlier this year.
I have BT7 front discs and stock late BN1 rear drums. I just spoke with Moss and asked if they can mix and match but they said no, they come in prepackaged kits. I acnnot be sure but since Moss specifies different part numbers for BN1 versus BT7 rear hoses I doubt that ordering a BT7 will work for me.
I cannot find a listing for Cobalt and it looks like they supply a lot of vendors so I doubt I will be able to have them make up a custom set of hoses. Same thing with Goodridge.
I would like to buy a set of SS hoses from either one of these suppliers or someone else but do not feel like buying two kits to harvest the parts I need for one car. Does anyone have any suggestions as to a source?
I believe these guys will make for you or sell you what ever you need.
Making hydraulic hoses for any hydraulic shop is often just a function of whether or not they have or can source the fittings and swaging dies. Find a shop, bring a hose by for them to look at and perhaps they can make some for you. It might not be a big deal.
Check with a local farmer. i know a friend of mine over here gets hoses made all the time for his equipment. And it is cheaper.
After checking out the link to Oldphartz Parts that Ausmhly inserted in his post #6 I made contact with them and received an immediate reply from Steve Christianson who said that making up such a kit is no problem for them. He is on PST time so I have a call into him to finalize the order.
I'll give feedback after I receive and install the parts but whether he is making the hoses or buying them from a supplier it is nice dealing with a seller who has flexibility.
