Wheel Bearing Race Installation
BruceAllcorn
Does anyone have a tried and true method for installing new front and rear bearing races? This is for the front wheels on a BT7 Healey. I have the old ones out and I'm trying to find a correct way of installing the new ones.
Thanks in advance:feedback:
steveg
I've used the Harbor Freight bearing and seal drivers - before that, appropriately-sized pieces of pvc pipe make cheap drivers that won't hurt anything.
For me, boiling the hubs in water and freezing the races in my garage freezer worked. If you do that they should tap right in - make sure the taper of the race is properly oriented!
Similar to Steve's method, I've always had good luck by keeping the races in a freezer for a few days (I've never had a "deep" freezer, but I can appreciate its usefulness here) and heating the hubs in an oven. If you have a pair of__stick__welder's gloves, you can take the hub up to 250*-300*F with no problem.
The really fun part, and you need to be as accurate with your "drop" as possible, is the race will fall to the bottom of its bore with no hammering required. It makes the most rewarding clink that you can imagine!
Once only, out of dozens of times, did the race get cocked in the bore; the race will quickly equalize temperature and get stuck, and then has to be driven home__after you get it parallel again__with the drift & hammer that most folks used to begin with.
Chris_Masucci
I usually slice one of the old ones through, and then flip it over on top of the new one. That way i can tap on it with the perfect size driver and any steel drift or hammer without fear of damage. Helps keep things square too. The sliced old race pops out easily after use.
B
BruceAllcorn
Thanks for all the great info. I went to Harbor Freight and bought one of their bearing and seal drivers ($30). They matched up size-wise perfectly and made quick work of the races.
bob hughes
Nice one Chris, I use the old race myself up to a point, then drift the bearing home gently going all round to keep it even. Then when putting the hub on the car - dry of course - tighten things up before shimming properly to make sure that the bearing is home. I never thought about slicing the old race - I will do that for next time.
:cheers:
Bob
busybrit
That's a good idea. I install many bearings and have an assortment of old ones which I've ground down the o/d to use as you do. Cutting them would be easier and faster.
C Spitfire rear wheel bearing Triumph 2
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Lin Cause of burned wheel bearing? Austin Healey 5
A Front wheel bearing issues Austin Healey 11
M Wheel bearing question Austin Healey 9
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
Bayless Need wheel bearing advice please Spridgets 4
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
R Front wheel bearing - end float Austin Healey 40
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
KVH General TR Front Wheel Bearing Felt Seal Direction Triumph 9
C Rear wheel bearing or other cause? Austin Healey 18
T TR2/3/3A Another wheel bearing thread Triumph 5
G TR4/4A Front Wheel Bearing Seal Triumph 19
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
steveg Spun wheel bearing traced to gasket thickness Austin Healey 16
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
S Problem removing front wheel bearing retaining nut Austin Healey 9
N Spitfire Front wheel bearing seal??? Triumph 11
Morris Another wheel bearing question Spridgets 3
Morris Wheel Bearing Shims Spridgets 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
7 General TR Chirping front wheel bearing Triumph 6
B Rear Wheel Bearing Oil Seal Spridgets 7
Morris Front wheel bearing installation Spridgets 4
H excessive wheel bearing shims? Austin Healey 11
NutmegCT TR2/3/3A TR3A wheel bearing? Triumph 7
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
TulsaFred Front wheel bearing grease packing Spridgets 26
G XKE rear wheel bearing replacment Jaguar 4
M Rear wheel bearing Spridgets 4
S Wheel Bearing Grease/Repacking Austin Healey 1
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
D MK2 front wheel bearing adjustment Jaguar 8
PatGalvin Wheel bearing grease seal blues - they continue Triumph 15
T TR6 TR6 front wheel bearing ? Triumph 5
tomshobby specific front wheel bearing questions Spridgets 8
N Spitfire Spitfire Timken wheel bearing numbers Triumph 5
ekamm Need Timken wheel bearing #'s Triumph 13
tomshobby front wheel bearing question. Spridgets 9
GBRandy Wedge TR8 rear wheel bearing noise / replacement Triumph 5
Jim_Gruber Wheel Bearing Grease/ Impact wrench on hubs Spridgets 11
bigjones Wheel bearing replacement question Spridgets 60
bigjones Wheel bearing nut torque Spridgets 11
T Bad front wheel bearing. Triumph 81
drooartz Wheel bearing grease, what should I know? Spridgets 4
I TR6 Rear wheel bearing help TR6 Triumph 6
