I started two reassemble my H6 carbs, and found that, using the the kit from Moss, the vacuum connection at the front carb was stripped and only made a very tenuous connection. I have had several suggestions and thoughts about this, and thought I should look or more experience. My favoured idea at the moment is to glue in the connector from Moss with its compression fitting, and a stub of tubing and then use an end to end compression fitting so I can disconnect the line to the Distributor if the carb has to be removed (which history says is certain to happen!), I could try teflon tape on the "thread" but doubt it would hold for long.
Any thoughts experience will be most welcome!
