TR2/3/3A Vacuum connection at Carb
TR3driver
Great Pumpkin - R.I.P
Just to add a challenge, the adapters have been retooled to metric threads on each end, but Moss only sell compression fittings with Imperial threads. More thought being applied.
That's absurd; they can't make a change like that and claim it fits. I'd return it as "not suitable for advertised purpose". I'll bet the one TRF sells will fit, and they even charge less for it.
mastaphixa
Bronze
Any thoughts on changing the position of the vacuum tap from the front carb to the crossover tube?
TR3driver
Seems like a bad idea to me. The port on the front carb is 'timed' to not produce vacuum when the throttle is closed, so you don't get advance at idle. Gonna be hard to reproduce that going from the crossover tube.
Dr_Mike
1. I phoned The Roadster Factory but they had no idea what thread they had on the parts so I gave up that idea in favour of gluing the male fitting into the original hole.
2 It was suggested locally to move the carb connection down stream, but as Randall notes the result would be unpredictable.
3 The other local suggestion was to cut the vacuum pipe and join the ends with push-on hose, as some other makes have done. This would enable me to remove the carbs without destroying anything else. I hope.
Meanwhile work has stopped due to cold weather! I am off south to warm up for a week.
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
B TR6 Vacuum retard late TR6 Triumph 4
